Replace home broadband with mobile plan?
Nuclear Boy
I am seriously considering this route after my current contract expires next year.
The downside is potentially losing our longtime landline number, or having to pay a few dollars each month just to maintain.
5G routers also not common and kinda expensive.
The_Davis
High Honorary Member
Deluxe Member
Seems like a few edmwers made the switch and still ok ba (from what im readin these last few pages).
Any chance theres spme sim card readerout there to connect to old routerand convert the old router to use just like a 5Grouter?
Erm dun have :(
yuri2
I recommend getting a cheap 4G router (below $200) for a start. Use 4G or 5G SIM which is downwards compatible.
More important is the data volume. Generally, you need min 300GB.
I have both 4G and 5G routers.
For 4G routers, tp-link MR600 ($160) is pretty good. deco X50-4G Wifi 6 mesh, is around $250
deco X50-5G, which I'm currently having problem after the firmware upgrade :
Strangely with Simba at 4G, download speed is at 100Mbps, giga 5G, download speed also same at 100Mbps.
I have to test further, but the deco new firmware keep crashing with giga 5G SIM, and holding on with Simba 4G.
It would seem the Wifi 6 mesh is superior according to speedtest on my mobile phone, whether I use 4G or 5G.
Nuclear Boy
For what I require, I think that's like unobtainium.
Because I also need the ability to connect my home telephone to it and use the calltime on the SIM if we were to forgo digital voice on fibre completely. Also a bonus to receive and send SMS on the same SIM that can be accessed on a web interface.
That's why for now gonna stick with fibre BB+voice for less hassle. I will reconsider if either prices come down and/or data cap increase in the future.
NovelLobster
Deco app has an section for receiving sms
Sambuca78
Prolink and Huawei have rj11 port for phone.
Nuclear Boy
I know... I meant the price of such device that has RJ11 phone port, several RJ45 LAN ports, router (and perhaps AP too) function built into one.
It is upwards of $250 at least. It will take some time to breakeven compared to staying on fibre (with VoIP), unless there is good justification to just make the switch.
~sabaisabai~
I buyed 5g router.
Try 5g card.
Cannot get 5g.
Change to 4g card.
Mifi router got slower speed than mobile tether.
Now got $5 plan.
thanks bro. chiu are da best! 😅
how much chiu paid for 5g router? got below $150 one or not
