Anyone signup for Eight Mobile $0 plan?
Jeremy1
If you opt for ESIM, it's super fast.
Morning you register for 8, then once done, they straight away send you an email asked you to activate your new plan using the temporary number and same day evening, your number already ported in and you can used your old number liao.
tanchoo1
Can share how long you take? Like today you apply tmr port over?
From Giga or Starhub to Eight, it will be rather quick. As long as you activate the SIM card before 12pm, it should port over at around 5pm on the same day if it is a weekday.
From non-Starhub MVNOs it will take a little longer.
Jeremy1
I don't mean to pour cold water on you but you probably already know that the recent Giga hack / takeover of eSim was possible because the Giga user chose a stupid password that was easily guessable or reused his password from another account so the hacker could easily login to his Giga account and request for a new eSim, thus taking over the number. From there, the threat actor could receive all OTPs from banks etc and managed to siphon off money from his accounts.
Eight works a bit differently but just bear in mind that eSim has such issues which pSim doesn't have, as the threat actor will need to physically get their hands on your pSim in order to take over your number.
That's why my lecturer also told us physical sim is more secure.
If a hacker took control of your phone, you can always remove your sim card to prevent him unlike Esim.
tanchoo1
You're absolutely right! Your lecturer is very wise.
And yet you still chose eSim... I guess convenience is more important for most of us.
To be fair though, most people will just blindly choose eSim without thinking. :ROFLMAO:
luckygal
Oh dear I have one line to port over from Republic.
enimen
What if the phone is still connected to wifi and can't be turned off?
Jeremy1
I used Esim when I was with Simba, nothing happened 😎
Yes, no need to physically remove n install sim card.
I think soon physical sim will be phasing out.
tanchoo1
Many phones still do not have support for eSim.
Only high end phones and iPhones currently support eSim.
Low end to mid range phones do not have eSim support.
pSim support will be around for some time more due to security reasons.
