 - Sep 16, 2018
Plan - HomePac 10Gbps Fibre broadband - 24 mths
$50.90/mth 24mth 10Gbps Subscription Discount - $13 off for 24 months
$50.90/mth
(U.P $135/mth)
Router
ASUS ZenWiFi BT10 (Pack of 2)
FREE
(U.P $22.09/mth)
Is this a good deal? $50.90/mth for 10GPS and free
Yes, I will say it is a good deal (S$13 OFF from the normal price), but not as good as the 6Gbps plan recontract offer at S$44.90 with a pair of ZenWiFi BT10 (S$15 OFF from the normal price).
But if you like to have faster 10Gbps plan (actually only up to 8.3Gbps due to XGS-PON limitation) than 6Gbps plan, just go ahead.
https://www.m1.com.sg/support/typical-speeds
TYPICAL BROADBAND SPEEDS MEASUREMENT AND METHODOLOGIES FOR FIXED ACCESS (DATED 1 January 2025)
Fibre Broadband Typical Download Speed Range| Theoretical Speed | Typical Speed Range* |
| 1Gbps | 931.4 – 941.0Mbps |
| 2.5Gbps | 1938.1 – 2096.4Mbps |
| 3Gbps | 2285.7 – 2579.7Mbps |
| 6Gbps | 2952.7 – 5714.1Mbps |
| 10Gbps | 3014.1 – 8234.5Mbps |
* The Typical Speed Range refers to the range of download speeds that users can experience 80% of the time based on the specific test conditions and parameters stipulated below. Testing Time Frame: October to December 2024.
