SIMBA Fibre Broadband
Network was down earlier. Both mobile and broadband were affected. Lasted for about 40 mins. Started at about 6.40am and ended about 7.20am. IMDA pls investigate.
https://downdetector.sg/status/simba/
As of 7:55am 6-Feb-2025
As for IMDA, it seems to me that they seldom deal with outrages from MR/VQ/WC/SIMBA.
drache
Hello. Just to share. My simba NLT activation was today between 130 to 7pm. By 4:22pm I received simba email notifying me that my NLT has been successfully activated. I plugged in my simba ONT, power on, connect my ASUS router, power on…. WOW, my internet is up and running!!!! Seamless activation and ONT was plug n play. Don’t need to pay for $39 set up. Thanks simba. I don’t have a laptop to test the true internet speed but with speed test on my iPhone 16 pro max I am able to get 3x the speed of what I used to get with M1’s 1Gbps fiber. Happy!!! Thanks
Yeah, my experience also positive, just need to test which line they activated (I thought it would be line 1, but turned out to be line 2 - I dont have active subscription on both - thanks to SH didn't turn up for the installation appointment).
To my surprise, ping to Chinese web like baidu is similar to other (~3ms), and the speed is good too
TickTechToe
Yes, I did removed the plastic cap on both ends before plugging in. SIMBA support informed that their Network Team has confirmed that the ONT is online, with all parameters functioning normally and the optical reading well within range.
I just bought the eero max 7 router and it still doesn’t work. I guess I will request for them to troubleshoot and setup my router at my home
Hi, any update? What is the cause of the problem?
hell92
Any feedback on using the eero max 7 router w SIMBA network? I read mixed reviews online, seems to be a decent option if you don’t want to be stuck with ISP-restricted routers.
anyone having their 10GB Simba BB to work with either Archer BE800 ot GE800?
No issues with that. SIMBA is using ONT so it is comaptible with all the consumer routers on the market. The only routers not compatible are those Singtel issued WiFi 5/ WIFi 6 routers with built-in Singtel VLAN profile.
But if you are looking at more cost effective model you may look at slightly lower end model -- TP-Link Archer BE805 (no 2.5G ports, no built-in OOkla SpeedTest utility). M1/MR users are dumping them in Carousell and the price is below S$360 and it will drop further to S$300 or even lower.
I bought one Archer BE805 at S$300 from M1 user recently.
I believe the wireless performance should be decent for its price of S$399 from SIMBA. The main limitation may come from the app and the requirement for subscription for basic security features.
Dongknows' review is bad but he may be based his opinion on the high price of US$600 at the review time (Jan 2024).
https://dongknows.com/amazon-eero-max-7-wi-fi-7-mesh-router-review/
Hopefully SIMBA users who are using Amazon eero Max 7 can chime in for their review.
Asus ZenWiFi BT10 or TP-Link Archer BE805 may be an alternative as well since M1 users are dumping them.
Asus ZenWiFi BT10 two-pack, BNIB listed price in Carousell is at about S$800, real transaction price should be lower. I believe the price should go down to S$720 soon for two-pack. Single unit price may be slightly higher than 50% of two-pack. The price will drop further since more and more M1 users are dumping the router.
TP-Link Archer BE805, BNIB listed price in Carousell is at about S$360, real transaction price should be lower. I believe the price should go down to S$300 soon. I bought one from M1 user at S$300 recently. The price may even drop below S$300 since more and more M1 users are dumping the router.
Hamlau
Thanks for the response and suggestions. I've considered BE805 before (looking at MR subscription) but I think I will need those 2.5G ports with BE800.. Get the better, more future proof router then pay lesser with SIMBA with only 360 days contract. Next year, the 10G prices will be even more competitive (i.e. cheaper) ヅ
