ZacharyA
- Apr 11, 2010
Looking for electrician, plumber any recommendation? Thanks
Dropped you a PM.
My current electrician & plumber is good and responsible, easy to work with.
Hi zacharyA, can pm me ur id contacrDropped you a PM.
i need some contract for electrician and carpentary for kitchen. Anyone have responsible and good recommendation can pm me.
Tx![]()
Mind to share your ID contactIf it is complex work it is better to go through ID with in-house electrician & carpenters so that they can run the wires within the carpentry works.
Otherwise, if it's standalone / straightforward carpentry and electrical works then you can get 2 different contractors to do it.
Hi @wievi83,My renovation was completed in 1 month and 1 week. I didn't do any tiling/wall hacking so most of the work is actually in carpentry on the living cabinet/tv console, 3 bedroom wardrobe, study room partition, and master bedroom headboard. Also have the additional aircon works, painting, plumbing, and electrical works as well. The quoted price is cheaper than the one I get from L*vsp**e and St***y Ho**s***d. The latter one told me that my reno might take 2-3 months but the ID that I engaged estimated it will take roughly around 1-1.5 months and he managed to complete the reno ahead of schedule
Overall, I'm quite satisfied with my ID's work since the carpentry result is top-notch. The carpentry fabrication only took roughly around 2 weeks. One thing to take note of is that he might be a bit slow to reply to messages since he is also working on many different reno projects, so you can't expect an immediate response from him every time.
Just PM me if you're interested and I can share his contact
Hi Petslave,Hello,
Genuinely sharing a contact for direct contractor work.
Responsive, and genuine .
My place is currently under renovation and would be more than happy for you to see.
Sharing to make renovation more affordable .
PM your contractor pleasemy contractor is ok. not the most exp, definitely cheaper than ID and they have their own local factory do furniture. My ID friends also say my contractor their furniture price quite cheap one. And they now have their own so call ID designer liao can do drawing. Downsight is you need to go choose own tiles ba
i can't pm...PM your contractor please
