Breaking: Trump hits Singapore with 10% Tarriffs
priore
U know how trump derive the “tariff” or not? Suggest you go read up first before commenting.
his reciprocal is also wrongly used. Only the ill informed will think what he says is correct
I think you missed my point entirely.
I'm not asking how trump derive the tariff to "tax us".
I'm asking how he came to the understanding that we taxed them 10%.
https://www.theguardian.com/business/2025/apr/03/trumps-tariffs-the-full-list
The right column that reads "Tariffs Charged to the USA".
shikoo
Pass 5% to everyone including us instead of passing 10% to usa consumers, need to keep usa consumers happy
havoc23
Shop owners very happy, Good chance for them to increase the price again..
:vijayadmin: :vijayadmin: :vijayadmin: :vijayadmin: :vijayadmin:
archie7
https://ustr.gov/issue-areas/reciprocal-tariff-calculations
Basic Approach
Consider an environment in which the U.S. levies a tariff of rate τ_i on country i and ∆τ_i reflects the change in the tariff rate. Let ε<0 represent the elasticity of imports with respect to import prices, let φ>0 represent the passthrough from tariffs to import prices, let m_i>0 represent total imports from country i, and let x_i>0 represent total exports. Then the decrease in imports due to a change in tariffs equals ∆τ_i*ε*φ*m_i<0. Assuming that offsetting exchange rate and general equilibrium effects are small enough to be ignored, the reciprocal tariff that results in a bilateral trade balance of zero satisfies:
any math experts can deciper tis?
In the context of imports and exports, the formula:
can be interpreted as a measure of trade imbalance or adjustment. Let's break it down:
Interpretation of Variables in Trade Terms:
  • Δτi\Delta \tau_iΔτi: Represents the relative trade adjustment for a particular product iii.
  • xix_ixi: The export value of a product iii.
  • mim_imi: The import value of the same product iii.
  • ε\varepsilonε: A trade sensitivity factor (could represent elasticity of trade, exchange rate effects, or policy adjustments).
  • φ\varphiφ: A proportionality constant, possibly reflecting economic scaling, tariffs, or trade policy adjustments.
  • mim_imi: Appears again in the denominator to normalize the difference between exports and imports.
What Does the Formula Mean?
  • The numerator (xi−mi)(x_i - m_i)(xi−mi) represents the trade balance (exports minus imports). If positive, the country exports more than it imports (trade surplus), and if negative, it imports more than it exports (trade deficit).
  • The denominator normalizes this trade balance by factoring in ε\varepsilonε, φ\varphiφ, and mim_imi, making it a scaled trade adjustment index.
  • A higher Δτi\Delta \tau_iΔτi indicates a stronger adjustment or deviation from an expected trade balance, suggesting potential trade policy intervention or economic shifts.
Possible Applications:
  1. Trade Policy Analysis – Governments may use this to assess trade imbalances and adjust tariffs or quotas.
  2. Economic Forecasting – Helps in predicting trade trends and evaluating the impact of exchange rates.
  3. Supply Chain Optimization – Companies might use it to balance imports and exports efficiently.
Let's consider a real-world example using the formula in the context of trade balance analysis.
Scenario:
A country is analyzing its trade for steel (iii).
  • Exports (xix_ixi): The country exports $120 million worth of steel.
  • Imports (mim_imi): The country imports $100 million worth of steel.
  • Trade sensitivity factor (ε\varepsilonε): Assume 0.05 (this could represent the elasticity of trade or exchange rate effect).
  • Proportionality constant (φ\varphiφ): Assume 0.8 (could represent tariffs, trade policies, or economic scaling factor).
Applying the Formula:
Δτi=xi−miε⋅φ⋅mi\Delta \tau_i = \frac{x_i - m_i}{\varepsilon \cdot \varphi \cdot m_i}Δτi=ε⋅φ⋅mixi−mi
Substituting values:
Δτsteel=120−1000.05×0.8×100\Delta \tau_{\text{steel}} = \frac{120 - 100}{0.05 \times 0.8 \times 100}Δτsteel=0.05×0.8×100120−100 =204=5= \frac{20}{4} = 5=420=5
Interpretation:
  • Δτsteel=5\Delta \tau_{\text{steel}} = 5Δτsteel=5 indicates a strong trade surplus adjustment for steel.
  • A high positive value means the country is exporting significantly more than it imports, suggesting a competitive advantage or a potential policy intervention (e.g., relaxing export restrictions or increasing import duties).
  • If this value were negative (i.e., more imports than exports), it would indicate a trade deficit, signaling a need for trade policy adjustments (e.g., reducing import dependency or increasing export incentives).
Conclusion:
This metric helps policymakers, businesses, and analysts assess whether a country's trade in a particular commodity is balanced, surplus, or deficit and how sensitive it is to changes in trade policies or economic factors.
One Month Notice
Tariff noob here, how does the increase tariff to sell to USA , and companies will pass the increase to US customers, so what is it affecting SInkies?
Anyway SG only 10% tariff you all so complaining, vietnam how?
Singapore is net importer. So when they say tariff increase cost to sinkie. I can only think of 2 reasons.
1. USA buy higher price raw material from other countries due to tariffs. End product more expensive due to it and when import to SG we have to pay higher price.
2. Singapore makes component to sell to USA . USA buy component at 10% more. And add the 10% to end product which when sell back tk Singapore result in increase in cost by 10% of the component.
Tariffs normally hits producing countries (net exporter) hardest not consuming countries (net importer) like Singapore.
Most of the ppl here commenting otherwise are just paid shills to diss the Tariffs and create misinformation.
Cheers
radish
Emeritus Honorary Member
i clap for st. quite a positive spin. i almost felt gd abt it if i didnt know any better.
its like getting shot by a gun but get congratulated for not being shot by a cannon.
technically its not wrong but the reality is we should always face the cold hard truth and not live in our own self fabricated wonderful world bec when reality come clashing down, it is wat is it.
:cry:
11.11.
4Dluckystrike
Since our tariffs is one of lowest in asia, just send goods here chop made in SG and ship out.. earn back 10 percent..
