yokine3a
- Aug 20, 2008
Possible, 肩夾挤 & 五十肩 are slightly different, many ppl won't know the difference.Its impossible not to know u hv frozen shoulder...theres no ambiguity
So what exercise did he ask u do?Came back from therapy
Physiotherapist said my case not frozen shoulder. Its due to my old injury and not moving my arms often
he said frozen shoulder symptoms is pain at night/when sleeping
I always sleep on my right side (side sleeper) and i often drink cold drinks. I think my condition is shoulder impingementChatted with my TCM masseur about frozen shoulder.
He shared:
Most FS cases are caused by 气血不足. The more 气血不足 a person is, the longer it will take for that person to recover (the FS condition can be for life).
So in order to 治本, one needs to have proper diet (more protein), exercise, and get some sunlight (to 'dispel' the 寒气 in the body). Avoid aircon + no cold food/beverages, keep warm if in cold countries. Can take some TCM med to 驱寒活血补阳 to speed up the recovery process. Acupuncture has a 补气 technique that one can also try.
Surgery can help to release the FS but if one is still 气血不足, the FS will sure to return some time later.
So the 'solution' is to make sure that one is 气血足, then will not have FS or can recover from FS at a faster rate.
*气血不足can be hereditary but most of the time is caused by one's habits.
I had frozen shoulder since last year.Which supplements good for frozen shoulder? Is caltrate uc-ll collagen tablet good?
I had that long time ago.Doc recommend opp.But I resisted,had painkillers,then lie down face up and maintain weight down to rebuild the muscles worn out the wrong way.If you lifted up.reverse the muscles direction by pushing down, using gravity and painkillers.It will reset and rebuild the muscles in the correct way.Be patient,and do it when you are free, repeat it, until it disappears.The body is wonderful,it heals itself,if you know it, plus your mind power.makan better food loh, u are what u eat afterall ... what else to do, if not see doctor ...
You sure this is Frozen Shoulder? What you describe more like stiff shoulder... can you lift up your arm straight up?Recently its getting worse. Just stand 9 hours at work and whole shoulder became stiff after work every day.
how to get better?
Yup, not a good time... my both shoulder kena.. after ultrasound scan one side of the shoulder rotator cuff tendon got a tear... not broken but got tear.. that is why so painful.. really pain until cannot move type...Yours does not sound like frozen shoulder. When you have it, you can't even lift your hands above chest level without feeling a sharp pain. And it won't go away by doing some exercises. Both my shoulders kena but at different time. Each took abt 1.5 years to recover. Even so, the range of motion is lesser now.
They give you pain medication oral and plaster... and ask you go physio... I go a few times and got tired... and stop going even the doctor appt also dun bother.. over time got better and range of movement back to about 90%...So when rotator cuff partially torn, what was advised by doctor? Any medication required?
