Xiaomi vacuum robot users lip lai please
MacSpicy Cheeze
Hi guys, I have a problem with my vacuum/mop robot it is a x20
It does not wet my mop pad, I have tried cleaning the wash station, check for blockage in the valve and there is none.
Is there anyone experiencing the same as me
crandfs
Maybe the seal of your membrane pump damaged, or got algae or other particles blocking its hoses
iiop00
Hi, can I check if anyone has issue for Xiaomi x20 max clean water tank leaking after mop cleaning? Is it normal?
babywoolf
My xiaomi mop 2 pro battery cannot last after using for 3m years. Anybody knows where to replace the battery?
ZippyRa
hello all i just bought my X20 Max recently. anyone can advise what cleaning solution you all using please.
derekliu
Me too wanting to know as just bought the same model too. Currently only using water for mopping.
LoneTraveller
I am, using bio home floor cleaner for my x20+. Just use 1/4 cup will do and mix it in the clean water tank.
Dew36
cn-11134207-7r98o-lnvkdojm5z1727
Using this for my x20 pro.
Read HWZ Forum Rules!
