jasvonvios
- Sep 13, 2015
$208 for s20 plus, s22 plus is cheaper. Their price is available on their website.May I ask how much did Mister Mobile charge to replace the screen?
By buying Samsung?I never encounter green line lcd before.
How you all got it one?
By buying Samsung?
I never had it on any of my display panels. Maybe because they're not Samsung... (IPS LCD confirm is from LG)
I don't know. Maybe phone or TV.
I never encounter before. I using samsung all the time.
They say LCD green line appear quite often so i wonder how it is look like.
Phone I guess... And it is their OLED panels, not LCD.
I guess abnormal pressure being applied on the panel and/or connection?
My previous LG TV (IPS LCD) have glitchy lines at the bottom in its final few months. That's after almost 8 years of constant use. Should be completely different reason (not due to design flaw).
whether OLED or LCD doesn't matter.... just that it is from samsung TV or samsung PHONE.
Anyway thanks for sharing.
I wonder how those peoples got this???
I think it is by design. My previous LG LCD TV developed the same issue after around the same amount of time. The only difference is that I use mine for more hours each day so the line appeared after 3 years then soon the whole area below it flickered the turned black the after that the line went higher and higher. 3 years equals 8 years because I googled average tv usage per day and when divided by number of hours my tv was on, which is in one of the settings options, it equalled 8 years.Phone I guess... And it is their OLED panels, not LCD.
Got tutorial on how to make green line appear. Just knock on the bottom edge of phone. The phone in the video is a55.Phone I guess... And it is their OLED panels, not LCD.
S24 kena liao? Share some photos pleaseMoi brother s24 kena, just after software upgrade, he feel very sian, I told him don't buy Samsung, buy china phone
Sent from Oppo Find X8 Ultraman
I read somewhere it is due to ovearheating during software upgrade.I always dun understand why software upgrade will cause it. If it is, means samseng deliberately caused it?
I dont understand how people can stand the green line on their phone.
S24u user here
Maybe phone being flexed while in pocket, over time, the connection kena? Design Flaw?
