harbinger255
- Sep 15, 2006
MOI AISSSS
Can sic the background? in English
actually got article when it first happened? cannot recall ****.
But those IV drip is the smaller needle on the back of your palm or near the wrist area, it's ok.... Easy
Just a bit inconvenient when you want to shower and the drip haven't finish, must wait for as long as 3-4hrs
did once several years ago. no i dun recallHave. You got do blood donation in SG before or not? They will inject first, wait 60s, then poke you with the big one to draw blood.
If ladies they give iron supplement tablets also to replenish.
bottoms up
i guessed Ian Fang wanna be the Singapore version of Kris Wu after failing to become Singapore G-Dragon. dunno if he be deported back China bo.
https://mothership.sg/2025/05/ian-fang-pleads-guilty/
Back in Jan when news out the identity wasn't revealed
this part is seriously sick man.https://mothership.sg/2025/05/ian-fang-pleads-guilty/
Last time in medic course we had to do 10 times of IV, real arm. Not dummy arm.
Max 2 tries each time. First time if fail then change hand
At the time of the offences, Fang was an acting teacher with a child modelling school with students aged four to 14, CNA added.
er.... nothing to do w that.
Just the feel and vibe. coming from personal life experiences being alone aboard, need to be very wary of people of this vibe, usually with 1 look, i probably have to make a decision to quickly walk away. I have met with ppl who are players, may it be male or female. but this one is different. feels like a predator thru n thru
Good thing about blood donation in SG is that they use anesthesia
think one niece bias is Rosie and the other is Jennie as what my sister say. but i keep showing her the blackpink vinyl i got to gian her.wah which one is her bias ? the singer, rapper, dancer or the 4th member ?
i requested no anesthesia once... cause i saw someone doing it since they dont like foreign stuff on body. gek kiang, also do the same. really is kimochi max![]()
Have lah. Part of their sophave meh? the last i did, its just poke needle there n then after alcohol swap.
i remember in the past, they will inject something before poking you.When was the last time you did? I donate at WestGate outlet they use anesthetia.
nowadays is wipe some very cooling numbing gel.have meh? the last i did, its just poke needle there n then after alcohol swap.
Same i also go westgate. But before they set up westgate outlet, I used to go to the one at HSA. I can't recall last time at HSA if they got use anesthesia or notWhen was the last time you did? I donate at WestGate outlet they use anesthetia.
