BTW, nothing wrong to go with 10Gbps plan either, if you need a mesh solution, at S$50.90 per month and two Asus ZenWiFi BT10.
https://shop.m1.com.sg/fbb/plans-bundles/fbb-plan?plan=HOMEPAC_10GBPS_24
https://shop.m1.com.sg/fbb/plans-bundles/fbb-plan?plan=HOMEPAC_6GBPS_24
Difference of the 10Gbps plan and 6Gbps plan, both with two ZenWiFi BT10, is at S$4 per month (S$50.90 per month vs S$46.90 per month, both new user offer). Bandwidth difference is probably about 2.5Gbps.
Take note that the 10Gbps plan is limited by the XGS-PON technology used -- max speed is at about 8.2Gbps, same for all local ISPs now.
TYPICAL BROADBAND SPEEDS MEASUREMENT AND METHODOLOGIES FOR FIXED ACCESS (DATED 1 April 2025)
Fibre Broadband Typical Download Speed Range
| Theoretical Speed | Typical Speed Range* |
| 1Gbps | 925.0 – 940.6Mbps |
| 2.5Gbps | 1971.4 – 2073.1Mbps |
| 3Gbps | 2216.8 – 2523.9Mbps |
| 6Gbps | 2102.2 – 5588.1Mbps |
| 10Gbps | 3002.9 – 8128.9Mbps |
* The
Typical Speed Range refers to the range of download speeds that users can experience 80% of the time based on the specific test conditions and parameters stipulated below. Testing Time Frame: January to March 2025.
