HirotoXeno
- Mar 6, 2020
You should then you will enjoy running.bro, i think i should get one good running cum walking shoes...to pamper myself .
thanks bro, if not , after walk long distance, sure will have blister.You should then you will enjoy running.
why not go henderson trail walk? easier as well before you go bukit timah.anybody familar with bukit timah trail walk?
can share?
blister you might want choose those wide type shoe for flat footer asics have alot..thanks bro, if not , after walk long distance, sure will have blister.
my new saf saics i think abit too long...but last weekend wore for the 22km walk, i find it okay.blister you might want choose those wide type shoe for flat footer asics have alot..
i walked to henderson trail many times, i am planning to go next Sat to bukit timah to recce.why not go henderson trail walk? easier as well before you go bukit timah.
You can try the asics kayano series lo . True to size too ,comfortable good for easy run 5k to 10kmy new saf saics i think abit too long...but last weekend wore for the 22km walk, i find it okay.
bro, can get it at chervon or bata shop?You can try the asics kayano series lo . True to size too ,comfortable good for easy run 5k to 10k
$150+ men's shoe asics kayano 31 at lazada look for those with wide versions.bro, can get it at chervon or bata shop?
how much roughly the shoe cost?
bro, that is expensive.....$150+ men's shoe asics kayano 31 at lazada look for those with wide versions.
Compare to see a doctor or experienced pain with commercial shoe.bro, that is expensive.....
noted bro, i need to save first....Compare to see a doctor or experienced pain with commercial shoe.
The hot weather really pit me off exercising..
