The Plastic Model kit hobby thread
gilcrest
Ya. Bought a couple of these.
Dun dare to put together for the same reason. 32mm leh... :(
32mm literally test your skills when painting
JAson1980
i buy the tamiya liner
try abit not bad
but ya i heard review say they are tough on the plastic so i stop using.
buy some brush and new water base paint
hope it works
i cant afford, nor have the space for air brush
buy those all in one airbrush system easy to use,.
i got a set of non-clean airbrush from taobao
Both great for starters and not that expensive
JAson1980
This is the biggest model kit i have. :s13;
PikaPika33
High Honorary Member
Thanks of the intro. Didn't know of this shop, maybe will check it out soon.
i feel the location not bad.
good for people who dont want go to the east
although not always the cheapest, they got some girlpla that others dont carry
PikaPika33
let me try out more on hand brush first and see if i can do it :s13:
Itsthatguy
Yah, near mrt and hc.
Normally, I go bras basah complex arts friend then to hobbypoint in one trip :ROFLMAO:
NeonX
any place to air brush or not ah? Haven't really done it in 10+ years, lack of space since there's pets around the house
Itsthatguy
last I know was Arumugam road that Gundam hobby shop (hobby art gallery) located in an industrial estate in Machperson. Maybe you can call them see if they still have the airbrush classes and area.
NeonX
hmm ok, not sure if can rent a space by the hour
NintendoSwitch
Think only HG kit line getting bigger. RG release getting lesser and MG lines even worse. Moi only build MG. Alot of kits still waiting for a 2.0 release :(
Ish it leeally true dat peepur prefer more parts? HG ish thr best ratio of parts to complexity. Those super complex kits might have limited building appeal to the average buyer. Buy one liao cannot build finish so unlikely to buy another.
