radioshack
- Aug 16, 2005
Is it significantly cheaper there?
I made Hoya lenses at KSL
Mine is Korean frame (180+myr)What's the price?
I made hoya lense for my son. $500+ without frame in sinkapore
is it more expensive to do it SG? or about the same?Got my IC Berlin for 1500myr thereabout including hoya lens. Berlian KSL.
Bought a back-up normal glasses MYR300+ including lens because my grandfather wanted to make and buy 2 cheaper. Some random shop in mid valley.
Got Zeiss lens some years back I think 1.5 times a hoya? Found no difference so just used back Hoya for my next pair.
Yes, much cheaper than in SGIc berlin frame so cheap in jb?
this one crazyPrice in Dec 2024.:
Lindberg frame 5534
- sgd900 from Capitol Optical
- rm2500 for the most expensive model, this is before discount
Zeiss Progressive Smartlife Individual 1.67 Photofusion
rm6000 x 0.75 - JB KSL optical shop
Zeiss Suberb 1.5 photofusion
- SGD1440
- rm3050 x 0,75 = rm2284 - JB KSL optical shop
do in msia definitely much cheaper...frame is cheaper, lens also cheaperis it more expensive to do it SG? or about the same?
u don't need to get this range ma. in SG, it's more than 2kthis one crazy
u can always msg the shop to enquire price, availabilityDo they have Oliver people frames there ? I'm used to their frames and using shamir lens
Ya did in Berlian KSL at least 6-7 pairs of IC Berlins by now throughout the years, they always give me a good deal. I think the prices went up slightly in recent years. But when I check in SG, almost $800+ for frame alone if i remember correctly.do in msia definitely much cheaper...frame is cheaper, lens also cheaper
