Encouragesome1
- Jan 12, 2023
Bolon frame lenses z something also 5xxWhat's the price?
I made hoya lense for my son. $500+ without frame in sinkapore
My degree 6xx 7xx super high
Mine in sgIs it significantly cheaper there?
wow sounds very worth it siaJust did a set in KL, Zeiss ClearView Photofusion 1.6, 950RM for the lens.
Cheaper than in SG for sure.
If can control its goodI made hoya myopia lense for my son.....actually orth-k contact lenses is very effective in controlling
Why not ready ? Does he need to adapt or something ?myopia. But my son is not ready for it
I use cheap frame because the lens already very ex and I can't afford expensive frames too. So I will have to take good care of it to ensure they last...Just curious. Why you fixed premium lens in cheap frame? Won't it be wasted if your frame is broken earlier than the frame? Of course you can find the similar frame size if the frame is broken, but i remember quite troublesome and usually the optic shop keep pushing you to change everything.
Last time i choose branded frame like tag or ic berlin when i use it with zeiss lens.
Eye health r for life man
How long do you need to wait to collect? Do you have to place a deposit and if so, how much?Just did a set in KL, Zeiss ClearView Photofusion 1.6, 950RM for the lens.
mind sharing where you got it in SG? Thanks.Mine in sg
Zeiss Clearview + With bluelight
1.67 index
$265 SGD (not including frame)
2024 at local sg shop. If malaysia cheaper can go buy
I can understand. I don’t even dare put contact lenses cos after that I can’t take it outHe doesn dare to allow me to place contact lenses onto his eye balls
https://maps.app.goo.gl/j1XEP63sSxNcGjm1Amind sharing where you got it in SG? Thanks.
You under the delusion expensive frame = last longer?Just curious. Why you fixed premium lens in cheap frame? Won't it be wasted if your frame is broken earlier than the frame? Of course you can find the similar frame size if the frame is broken, but i remember quite troublesome and usually the optic shop keep pushing you to change everything.
My parents go there too. Used to go the bishan branch until the ladyboss passed away.
i dont really like the people here though.My parents go there too. Used to go the bishan branch until the ladyboss passed away.
I always laugh at the ppl here buying so exp spects trying to justify their spending lol
Cheap glasses I also have alot I just chuck them to one side usually. Are cheap things exclusive to you? Lol.My parents go there too. Used to go the bishan branch until the ladyboss passed away.
Went to focus point at klcc, for Zeiss lens need to wait a day, pay in full to confirm the order.How long do you need to wait to collect? Do you have to place a deposit and if so, how much?
