Recommendation for portable Air Cooler ..
newcell
Yes got cold air without it filter no.
As mentioned, there's cold air without filter. Then no need to top up gas.
When service time make sure they DO NOT dismantle any part of the room unit.
Just ensure they only do cleaning to the fan unit and the interior.
Lchlch
Ok noted.
I also need them to check compressor...compressor fan keep turning even I off the air con.
deathan9el
Honorary Mentor
was at NTUC Finest earlier
cheapest air cooler is from Toyomi
priced at $2**
the rest of brands above $3**
anw good luck to ts for the intending AC service :o
deepblue_82
portable ac will need to have exhaust else it will not be cooling...
the midea is 9000btu....
very very noisy my office just installed one...take so long to cool down a room
400sgd
Lchlch
priced at $2**
thank you bro, no choice , need to check the compressor.
