Xiaomi vacuum robot users lip lai please
deokiejisoo
Anyone tried the new s40C ? Can't seem to find much information. Just need a sweeping robot for cat fur. Don't need mop. Would that be ok ?
dev_stg_prd
my roidmi eva like going to uplorry, can't really go back to base. always in/out adjusting.
looking at something
- with base station
- 2 reservoirs
- rotating cleaning ( not dragging )
- can cut hair ( if possible )
- i don't have pets/carpets
- budget $600 to $1000 ( lower the better)
nothing too expensive.. thanks
boxedfish
- with base station
- 2 reservoirs
Xiaomi X20 max checks out all your requirements. during shopee sales can get around $500-520
dev_stg_prd
X20 max really around $500? not typo of X20+ hor?
for the vacuum suction.. actually how much is enough ah? 8kPA ?
also if want this hot water cloth cleaner ( is this useful or gimmicky? )
did I list features that are important? Tks
boxedfish
i managed to get at $500 during 6.6 sales..
suction i am using medium power and is good enough.
i never use hot water, using warm water.
Nakedtoes
The cleaning solution can diy... Mostly they use alcohol and some drop of dish washer soap. So far I squeezed in few drop of dish washing liquid into the clean water.. Use for 2 years no issue. U can see the floor clean much better too. Alcohol is u add if u need the floor to dry up faster.
ultraman85
Being seeing issue with X20max, is the x20pro better? Any X20pro user care to share ur experience.
I am contemplating between these 2 and the max is just $50 more
taotato
Hi, does anyone have problem claiming warranty from Roborock/Dreame after using solution sold from third party also original but likely from China ?
ZippyRa
Need some help on my schedule clean up not sure if anyone facing the same issue.
I tried to schedule clean up for custom room however I can't seems to do it. The custom room option is always grey off asking me to go to homepage to set up my custom map.
I tried selecting a few room to try out on homepage turn out well however when I went into the schedule clean up page the custom map option is till grey off when I am back to the home page instead of the rooms I select it is back to the whole map.
My X20max is not able to clean and mop my whole area in one charge because at around 30% it will return back to dock for charging so trying to do 2x schedule clean up.
Elon Jobs
I just tried to schedule clean up for selected area on the Mi home app. It worked. Using X10+
klim668
Just bot one last month for my mom's home. It's a decent robot for its price. Quieter than my other models despite its higher suction power. I love the huge dustbin inside but think the water tank is too small. If you are using it for vacuuming only, then this is not an issue for u.
One problem is I've not seen its accessories available on the market yet...maybe need to wait for a while.
deokiejisoo
Thanks I also bought it. Just to vacuum cat hair and some dust on a daily basis. Does the job, no complaints.
eyz
planning for a vacuum cleaner?
any good that can mop and vacuum thoroguhly?
those that can go over carpet and vacuum the corners, is it a basic functions now, or need to pay a premium for it?
dreamcast18
same qns...i see x20+ for 499 right now from mi.com
x20pro is 559...$60 difference...which is a better choice?
dreamcast18
Went with the pro for $489. Could have gotten it cheaper in TW...but too heavy to bring back.
