70-year-old man allegedly hit by cyclist behind Yishun bus stop, calls for 'dismount and push' sign
Tom Sawyer
if japan such a big country can get all their bicycle to be registered and mandate all their cyclist to get mandatory 3rd party insurance, i don’t see why singapore such a small country cannot do so.
Because Singapore is not as homogeneous as Japan and it is important here that the locals need to assimilate into FTs' culture... So it is very difficult but I am confident that the authority here is monitoring the situation.... as usual ...
fortunehunter
You realize the pcn or shared path markings goes behind the bus stops at certain places now?
Buangkok have, Pasir Ris also have, Tampines as well.
Not sure. If so have this is a dame stupid design.
Full_Cream_Milk
Maybe there a lot of “bureaucratic work” to be done
To make common sense things like this happen.
Easier to implement tray return and plastic bag.
iammole
spore is a special country.... msia can apply gst for selected goods but spore can't.
Akky85
If the shared path or PCN is slated to go through the area then behind the bus stop is already the best location for that to go to. Areas with this are also usually enlarged further to accommodate that.
Based on how they are developing the network, you can basically expect more of such ''lame'' designs to happen.
Kain999
Pls lor, cyclists still demand the right of way and expect others give way at dismount and push walkways.....
zoossh
https://static.wikia.nocookie.net/dragonsdogma/images/9/97/Dragon%27s_Dogma_-_Tripwire.jpg/revision/latest?**=20131007015418Like that’ll help :rolleyes:
images
testart
Some PCN route are behind the bus stop
which is why they painted LOOK LEFT LOOK RIGHT on the ground
the authorities or designer knew is an obvious blind spot so give warning sign
but there no SLOW signage for cyclists
Even there is signage to dismount or slow, cyclists don’t comply
end up sometimes I see LTA deployed auxiliary officer to catch errant cyclists
dambio
Alot of places all will converge n no separation alr.
Shld make a no riding zone ard tis places. But some ppl wun care also la.
skytan13
70 year old need to be punished
how can he lobby for rules to reign in the actions of the HIGHER BEINGS
Tloslm
Very true. Japan can but Sg don't want
Akky85
No riding zone dun make sense de.
If for example, u make a section no riding zone, then what happen is (already happening actually) is that your cyclist groups is gonna take note, share it among community then cyclists either avoid the area totally or they go to the other side where they can ride without the sign, even if it means have ppl.
Context is for those with town centres etc etc.
Currently now some area already have TP cams mostly for PMDs but as PMDs are supposed to be on shared path and pcns only, cyclists will end up getting captured also.
Which then comes to the next point, what's the point of building a shared path there THEN input the policy of policing cams etc and discouraging the targeted segment from using the said paths?
Additionally, with shared paths and pcns now within town centres, it make sense for EVERYONE, cyclists included, to slow down, take note of their surroundings and make sure you look before you cross a shared path/pcn. This is no diff from crossing the road and from things like carrying a tray of soup and u look behind and make sure nobody is there before u spin around etc.
I will agree errant cyclists make the group looks bad and some of them really deserve what's coming to them.
dambio
Now d main issue is also how to get ppl to adhere to rules? As we've seen in many cases n in news.
U can enact all d laws n rules. But ppl dun care or adhere to it now.
