[CONSOLIDATED] Air India plane crashes at India's Ahmedabad airport
Zinna
Do you need to be in the cockpit and physically turn it off? Nobody can remotely program it to turn off right?
Pilots trained from where?
xiao.xin
The pilot make the mistake and decided to lie at that point of time when asked by the other pilot, their culture.
If the pilot admit his mistake on this spot, the error can be corrected.
I make the same comment. For all you know it could be the one asking the question the one that switched it off.
Heng I sold off all my SIA position on the high last week. Anything that gets involved in south asia need to siam far far.
Chalkycliffs
Tech support people always tell others to "restart" the system.
tmkedmw
This pilot youtuber made a very good guess long before news broke. He speculated that one engine malfunctioned and a pilot accidently cutoff fuel to the good engine.
That's different.
The 2 engines were cutoff 1 second apart, by moving the fuel switch from Run to Cutoff.
tmkedmw
Cutoff fuel at that low altitude is gone case liao... cos there is not enough time for the engines to restart and generate thrust needed to avoid crashing to ground.
xiao.xin
well, pardon my poor english.
it was 1 second apart, so i guess 'almost' simultaneously seems more appropriate.
Means is something like reflex when they cut the engine. Cutting off both together at the same time. I assume there's fail safe mechanism whereby need to do 1 at a time therefore having the slight delay
audiovideo
high time to redesign to stop pilot from itchy hand, just like the system lock the front wheels when speeding down runway
fortunecat
Hopefully that's really the cause. At least we know the plane never bo dai bo ji lose thrust during take off
Mystyque
Hypothetical scenario of what the youtuber meant
Engine 1 spoil.
Pilot wanted to cut fuel to engine 1.
Screwed up and cut fuel to engine 2 instead.
If there was any event that could require action such as cutting off fuel, the preliminary report would had mentioned it.
Also the most common reason to cut fuel is because engine caught fire or leaking fuel. Neither are applicable.
Mystyque
There’s no such fail safe. The 1 second gap is simply the time it takes to move hand to the other fuel cut detent switch, pull it up and flip it down.
Mystyque
I believe it isn’t necessary fatal if corrective action taken immediately. The problem seems to be the pilots didn’t rectify until 10+ seconds later. By then, the engines would need far more time to spool up to sufficient speed.
