Nvidia RTX5000 up to +30% better than RTX4000 (only!)
fkchon
damn insane fps on the 9950X3D, he seems to be able to hold 5.7-5.8GHz maybe hes not showing effective clock but the power consumption is lesser than my 285K.
fkchon
now that I switched ASUS PSU to Seasonic 2200W, I can push the GPU higher.
Seems like my 5090 highest clock it goes to is 3382, I think is average bin.
Can do this test either ASUS GPU Tweak or Afterburner, go to default settings drag power and voltage to max allowed then increase your clock frequency until it crashes while doing the simple rendering from GPU-Z. If you hit 3400MHz then you have a good bin.
kimsix
interesting find,
stock locked voltage = +404 offset = 3375mhz @ 1.085v. +405 will crash drivers
unlocked 100% = +395 offset = 3412mhz @ 1.105v. need to lower offset abit.
surprised the voltage settings have effect. but i reset it to locked. :o
this method seems align with my curve settings, +400 offset to the most important v/f points to get best performance
https://forums.hardwarezone.com.sg/...tter-than-rtx4000-only.7011311/post-156899164
fkchon
New age of GPU mining, each 5090 roughly $10 USD a day, you're renting out your entire PC with 5090 to people to use for AI workloads.
Humster
In SG, think 1 day the electricity the $10 cost not enough to cover. :flash:
badbad2000
I go opposite undervolt the gpu to draw only 400W or below and keep temperature not more than 65-67C. I prefer more quiet gaming environment instead of the fan goes crazy and trying to heat up the whole room. 😁
