Anyone stopped dumping toilet paper into the toilet bowl??
Mystyque
use bidet still have to wipe first.
i used to notice the poo stain underneath the toilet bowl cover, and was puzzled how come the stain can get to there.
it was then i realized my wife has been spraying right after the dump, with those stuff still sticking onto the hole. so you can imagine, when the jet water spray at the hole with the dump, the dump just fly all over the place in the toilet bowl.
advice: still have to wipe before water spray.
Didn't realize this but heng I always thought it was a bit yukky to just spray without wiping first.
1982-1994
Your sai too big? Unless you in Thailand our drain no issues lah. Anyway I now use bidet then tissue to dry
Recently the shape like durian
Otherwise always thick and long
Even without bidet, the poo stains splatter onto the cover upon flushing sometimes (I flush after covering)
Think of it, maybe the zuaing of the bidet water may end up zuaing the stains onto the floor too
still wash karchng after wipe so probably bidet is redundant
U will never want to use those public toilet without bidets unless really no choice.
So far only use MBS hotel toilet to PS ,there is always a cleaner standing by
Can flash first
Than use spray wash pigu
Than wipe , u will only use less than 1/10 of wad u using now
20 years ago, I used to just spray wash saikang without even wiping it ,can see the sais on the floor
Then spray at it into the floor trap
Totally change after shifting home in 2007
i try not to take a dump outside... at hm i use bidet... :o
Don't say dump, I only use mall or hotel toilet to pee
Rather lun and quickly go back home for a dump
If the main drain can choke, it's the main drain choke contributed by all the neighbours living in the same column.
That's why one of the pros of staying on high level to minimize such problem
If go for non "green"/water saving toilet bowl, less chance to clog
What's that?
FT PRIDE
Your wife is from Taiwan?
China does not have such nonsense.
China used to required you to throw toilet paper into a bin provided in each cubical. I am not sure have they improved now to removed this totally.
LoUsyGamER
What's that?
The flush is too weak to flush away all the toilet paper. I was travelling to some of the south east Asia countries earlier this year and Australia. Many of their towel flushing system is stronger than Sg one. Even with full load of toilet paper and human waste, 1 flush just flush all away.
I don't see what water saving and crap on their towel bowl.
coyote
I've been to few places in China years ago and never have I seen such thing. Only in Taiwan a modern city with a wayward infrastructure.
coyote
duno eh. ts thread title put toilet paper then few posts later mentioned wipes..
That is really no common sense. Anyone using wet wipes can try to use your hand to tear the wipes... Common sense will tell you it cannot be thrown into toilet bowl. If ts or his wife did that... Really is speechless.
titusilvering
Some idiot will purposely throw lots of toilet paper in public toilet to make people flush then flood the place :s22:
Actually when finish pang sai suddenly toilet bowl flood till overflow is sibei funny one. Cuz sai water every where then faster pew lang
