Here is not Taiwan or China.Inside loh
Wife told me to stop doing it but that means the toilet will be filled with all the sai bi if I were to bin the wipes in the toilet
use bidet still have to wipe first.
i used to notice the poo stain underneath the toilet bowl cover, and was puzzled how come the stain can get to there.
it was then i realized my wife has been spraying right after the dump, with those stuff still sticking onto the hole. so you can imagine, when the jet water spray at the hole with the dump, the dump just fly all over the place in the toilet bowl.
advice: still have to wipe before water spray.
Your sai too big? Unless you in Thailand our drain no issues lah. Anyway I now use bidet then tissue to dry
Even without bidet, the poo stains splatter onto the cover upon flushing sometimes (I flush after covering)use bidet still have to wipe first.
So far only use MBS hotel toilet to PS ,there is always a cleaner standing byU will never want to use those public toilet without bidets unless really no choice.
Can flash first
Than use spray wash pigu
Than wipe , u will only use less than 1/10 of wad u using now
Didn't realize this but heng I always thought it was a bit yukky to just spray without wiping first.
Don't say dump, I only use mall or hotel toilet to peei try not to take a dump outside... at hm i use bidet...![]()
That's why one of the pros of staying on high level to minimize such problemIf the main drain can choke, it's the main drain choke contributed by all the neighbours living in the same column.
What's that?If go for non "green"/water saving toilet bowl, less chance to clog
China used to required you to throw toilet paper into a bin provided in each cubical. I am not sure have they improved now to removed this totally.Your wife is from Taiwan?
China does not have such nonsense.
The flush is too weak to flush away all the toilet paper. I was travelling to some of the south east Asia countries earlier this year and Australia. Many of their towel flushing system is stronger than Sg one. Even with full load of toilet paper and human waste, 1 flush just flush all away.Recently the shape like durian
Otherwise always thick and long
Think of it, maybe the zuaing of the bidet water may end up zuaing the stains onto the floor too
still wash karchng after wipe so probably bidet is redundant
Totally change after shifting home in 200720 years ago, I used to just spray wash saikang without even wiping it ,can see the sais on the floor
Then spray at it into the floor trap
Rather lun and quickly go back home for a dump
What's that?
duno eh. ts thread title put toilet paper then few posts later mentioned wipes..Wet wipes cannot be thrown into toilet bowl. Please have some common sense.![]()
You have not seen public toilet in sg cannot handle tooOnly in overseas la. I think for countries like jpn or tw, their system cannot handle big load of toilet paper
Wet wipes , cannot throw into toilet. Unless use the ones that specify that can.wipes and toilet paper same thing? i heard some ppl use wet wipes, that one higher chance to clog
How you know what other users may have thrown inside? Like tissue paper etcYou have not seen public toilet in sg cannot handle too
Actually when finish pang sai suddenly toilet bowl flood till overflow is sibei funny one. Cuz sai water every where then faster pew langSome idiot will purposely throw lots of toilet paper in public toilet to make people flush then flood the place![]()
Why the if? Thread title already stated toilet paperIf ts or his wife did that... Really is speechless.
Sai too big and stronkHow come will clog? You dumped the whole toilet roll into it?
