ahnyaahnya
- Mar 3, 2010
Nowadays still have meh?If go for non "green"/water saving toilet bowl, less chance to clog
I think public toilets have a spray.at home can use bidet...
outside not everywhere have
I recall still have. My friend recently renovated his BTO and he managed to hunt for one without the ticks or green crap. I think need some effort to find one though.Nowadays still have meh?
Buy from Malaysia?I recall still have. My friend recently renovated his BTO and he managed to hunt for one without the ticks or green crap. I think need some effort to find one though.
I find that I have to flush multiple times when I use the water " saving" toilets. Especially after taking a dump. Otherwise got floating objects.If go for non "green"/water saving toilet bowl, less chance to clog
Our water is recycled over and over again. Yes, all the "Newater" we drink? Ahem...you know I know.Someone suggested installing those water jet washer to reduce toilet paper usage. You can try. Reducing water usage versus reducing toilet paper usage, I don't know which is greener?
BTO launches since feb 2016 started to have this eco-pedestal installed with OCS opted inI find that I have to flush multiple times when I use the water " saving" toilets. Especially after taking a dump. Otherwise got floating objects.
So dunno how that saves water
Why the if? Thread title already stated toilet paper
Sai too big and stronk
Need to check behind toilet bowl cover alsouse bidet still have to wipe first.
i used to notice the poo stain underneath the toilet bowl cover, and was puzzled how come the stain can get to there.
it was then i realized my wife has been spraying right after the dump, with those stuff still sticking onto the hole. so you can imagine, when the jet water spray at the hole with the dump, the dump just fly all over the place in the toilet bowl.
advice: still have to wipe before water spray.
Mostly toilet paper and loads of itHow you know what other users may have thrown inside? Like tissue paper etc
What's OCS?BTO launches since feb 2016 started to have this eco-pedestal installed with OCS opted in
Toilet paper can be made of recycled paper. However, most brands are not made from recycled paper. Even if recycled, it can only be recycled once lor...
Conclusion, not only is using water greener, you also get revenge for having others drink your "sai chui". Cannot everytime you drink other people's "sai chui" mah.
U Soup restaurant tycoon also need to diy meh.Toilet paper with **** can throw where? I know how to clear choke though. I use a mop to pump the toilet bowl. Always work.
How come toilet bowl can still flood with only sai? The sai too big until choke the bowl?Actually when finish pang sai suddenly toilet bowl flood till overflow is sibei funny one. Cuz sai water every where then faster pew lang
Will never gets clogged if one minimize paper usage by improving usage efficiency and heavy flush with holding press on the flushing button when the bowl is still not fully filled. Make sure that things that are not biodegradable like plastic bags for shower caps and soaps are not dumped into the toilet bowl ... this is a golden rule. Don't throw hair into it but coconut brush bristles are fine..Due to clogging sometimes
Mean original already choke just not visible maybeHow come toilet bowl can still flood with only sai? The sai too big until choke the bowl?
I am scared of sai water drips onto the floor ,and the need to clean the plunger thoroughlyI am very good at clearing toilet bowl chokes. Ask me how
Optional component schemeWhat's OCS?
I spot my wife's a strand of hair stick at the bowl sometimes ,I just flush it downDon't throw hair into it
no in singapore most dont have a spray unless u are talking about malaysiaI think public toilets have a spray.
Certain sector of our community need that
