TA20222025
- Jul 21, 2022
TS using A4 paper is it?
Because you pee more than taking a dump. You don't dump as many times as you pee.I find that I have to flush multiple times when I use the water " saving" toilets. Especially after taking a dump. Otherwise got floating objects.
So dunno how that saves water
Did u throw tissue paper inside toilet bowl?Inside loh
Wife told me to stop doing it but that means the toilet will be filled with all the sai bi if I were to bin the wipes in the toilet
Pee also sometimes need multiple times... unless leave floating paper for the next user ( who will probably flush for you)Because you pee more than taking a dump. You don't dump as many times as you pee.
So the saving is still substantial.
Need to check behind toilet bowl cover also
Didn't realize this but heng I always thought it was a bit yukky to just spray without wiping first.
I need this, any recommendation?So far the most effective one in my experience is the twin cyclonic flow, small flush also can clear big business most of the time.
No,but many toilet paperDid u throw tissue paper inside toilet bowl?
Use water betterI need this, any recommendation?
After pee, spray water ah.Pee also sometimes need multiple times... unless leave floating paper for the next user ( who will probably flush for you)
Use little paper only.After pee, spray water ah.
Use so much toilet paper meh ?
1 small flush is enough.
Try to avoid fallen hair in the bowl as they are not easily decomposed into small fragments. Close the toilet cover when not in use and comb hair outside the toilet. Cigarette butts also cannot throw inside the toilet bowl.I am scared of sai water drips onto the floor ,and the need to clean the plunger thoroughly
Optional component scheme
I spot my wife's a strand of hair stick at the bowl sometimes ,I just flush it down
Wash the holeInside loh
