zym.sg Mobile (Singtel MVNO)
twosix
from Erica : [09/10, 5:41 pm] ZYM Mobile: Hello! Thank you for contacting ZYM Mobile. I'm Erica, your personal AI assistant, and I'm here to help.
[09/10, 5:41 pm] ZYM Mobile: Yes. To qualify for the six‑month port‑in bonus from a non‑Singtel network, the number must not have been active on ZYM in the past 12 months *and* must not currently be with Singtel, Gomo, Heya, ViviFi, Zero1 or CMLink. I can’t check individual eligibility—please let me know if you’d like to speak to a live agent.
Wanted to sign this plan but the 12mth requirement stopped me. Z1 dun have such t&c and I'd go to z1 soon. Bye bye zym.
ShinnAsuka
Zym vs m1 Maxx peak hour Bishan station same spot. Zym even faster than M1 true 5g SA at times. Best is to just pay 1 month and test at the places you frequently visit to see which is more suitable for you.
I was at newton and zym basically little to no data.
Overseas now and the partner is worse than Simba and eight's
xsoldix
I’m waiting for esim and 5G+ network review then consider.
No rush for now.
TyL3r_DuRd3n
what kind of call ? WhatsApp or normal phone? volte enabled ?
i got two sim. zym and eight.
i set mobile data to Zym.
then, i made a normal traditional call via phone app.
I called the bank, when i wanna update something in my bank, it sent me a push notification for the 2FA, i never receive coz zym signal suddenly gone, no internet.
den i tried setting mobile data to eight, called the bank again. zym no signal again, but this time, i can receive the 2FA push notification to log in coz i set data to Eight 4G.
why like that siol!
A7997A
why like that siol!
On Samsung, there is a switch in sim manager labeled "Data switching and backup calling".
On other phones there might be something similar.
Do you have that enabled ?
I saw some reference saying to use 2 network simultaneously, that switch need to be enabled.
You might want to check that out.
gapboy
why like that siol!
suppose u cannot use different network for calls and internet concurrent try using one network
TyL3r_DuRd3n
after reading your post, i set the data the same as the sim card i m calling out. data is working.
but now got another problem, i cannot call out using zym sim card. why ah. :s34:
"call failed"
TyL3r_DuRd3n
i could be wrong but i dun see it in my iP15PM
gapboy
"call failed"
alot problem..disable 2nd Sim lol
JAYSCS
"call failed"
Hmm, that is strange, it could be Zym's setting does not address to certain phone's model setting? For your Eight SIM if operates with 1 SIM and removing the other SIM, can data and call operates simultanously? May be you can check with Zym instead.
But dual SIM operation can be quite tricky, eg. My Redmi Pad SE 8.7 can only send SMS with 1 SIM no. and there is no option to send with the other SIM no., there is no option to toggle which SIM nos. to send SMS at all, it is up to the device to decide which is the default. But my older Poco M3 has no such issue.
