gatx105
its a very decent build. Change 5600 to 5600G. Can last for at least 3 to 5 years. More if hardware does not fail you. If you like a bit of bling, go to shopee or carousell , get the AMD wraith prism cooler.
With B550 mobo, you can upgrade to better chip next time when needed.
Thanks. I'm a non RGB user, prefer air cool setup as I'm not that confident in self build.
deepblue_82
i think like that... intel 12gen and amd am4 maybe a mad revival coz ppl might turn to ddr 4 due to the prices..
Koenig168
deepblue_82
Koenig168
like that the prices no point... i remember 1 month back 5800xt was pretty cheap like 200+ only...
5800x3d nv did come down in prices.. now its going to the moon
long live am4 haha
The non-X3D 5000s are still reasonably priced. Even the 5600 can provide a decent gaming experience. I had the 5800X3D for more than a year before upgrading (when I got my 4K monitor) as my 5600G was sufficient for my needs at 1080p.
deepblue_82
dont think i will ever pay for a mad price for a x3d chip
beng035
5600g will come in handy when you trouble shoot your system when no display
difference, is very very marginal
soreloser
5600 is about 20+% faster than the 5600G in CPU limited scenarios.
5600G also only supports PCIE3.0, 5600 supports pcie 4.0.
I think the answer is pretty clear...
dasreich
Finally got a R7 7700 after last purchase of i5 gen4 in 2014, was using a i7 gen6 from office trash until the upgrade. Price in early Nov was 1.3K, and now it has risen to 1.8K with the RAM shortage. Lucky, didn't keep waiting ... should have gotten a spare 32gb DDR5 kit, but as I didn't know what PC spec would I get,I didn't get the chance to get it.
Hopefully on next parts upgrade, prices would fall back to manageable levels.
If you have a fair PC/Laptop, guess it's better to see how to refresh it again.
iceblendedchoc
Pg 1 is a reminder what price used to be on 22 Sep 2025 in case a revision is on the way
cheapest usable brand new rig, total: $343
core i3-10100 + asrock h510m-h2/m.2 se208techdeals
lexar 8gb 3200c22 ddr424techdeals
lexar ns100 128gb21techdeals
fsp hv pro 550w50pckaki
tecware nexus air m240tradepac
$500 pc, total: $466
ryzen 5 5600g + asrock b550m wifi se279techdeals
gskill ripjaws v 2x 8gb 3600c18 ddr452tradepac
lexar nm620 512gb45vii pc
entry level 1440p gaming pc, total: $998
ryzen 5 5600 + asrock b550m wifi se266techdeals
crucial p3 plus 1tb80dynacore
intel arc b580375dynacore
thermalright tg650s75dynacore
midrange gaming rig, total: $1511
ryzen 5 7600 + asus tuf gaming b650em-e wifi368tradepac
klevv fit v 2x 16gb 6000c30 ddr5135bizgram
thermalright phantom spirit 120 se48dynacore
lexar nm790 1tb101pc themes
zotac rtx 5060 ti 16gb twin edge609techyard
silverstone va-650g98bizgram
for this build tier and higher u should consider adding additional case fans, personally recommend the arctic p12 @ $12 each from mr doraemon @t258jgn.
if budget up to 2k, follow midrange reco but replace with the following: $1903
crucial t500 1tb108pc themes
powercolor rx 9070 xt reaper955dynacore
adata xpg core reactor 750w139bizgram
high performance productivity + gaming, total: $3160
core i9-14900kf + asus tuf gaming z790-btf wifi d5907dynacore
arctic liquid freezer iii 360mm147performance pc
wd black sn850x 1tb117tradepac
msi rtx 5080 shadow 3x1549dynacore
fsp vita gm 850w155bizgram
yukita
Hi all,
I'm planning to downsize my CPU case from a full tower to a small mATX, something along the lines of Lian Li A3, Deep Cool CH260, or JONSBO D32 STD.
Currently, I use a Corsair RM-x (2021) 850W full modular PSU, which is a Tier A+ from the PSU Tier List.
This psu has lenght of 160mm (not the standard 150mm), hence not compatible with the smaller case above.
I do have spare old Seasonic X660 watt, but i dont think should use that one.
My current spec: Ryzen 7600x, Gigabyte B650M Aeorus Elite AX, 96GB DDR5 6400 CL32, 3 nvme SSD with Zotac 5070ti.
Any recommendation for the PSU? Size, brand and model?
iceblendedchoc
Hi all,
how large is your zotac? For CH 260, a 16cm can actually squeeze in if your gpu isn't too long. I was using a 16cm full ATX PSU on the CH270 plus for the longest time before i bought a SFF PSU
abstrax
Hi all,
Most PSU is 160mm x 150mm. I tik u shld try fix 1st. U r not using iTX casing. shld be able to fit.
Koenig168
Hi all,
The Superflower Leadex III ATX 3.1 Gold is slightly shorter at 15 x 15 cm. Haven't tried Superflower myself so no idea about performance.
https://www.super-flower.com.tw/en/...1000w-atx-31-wh-20240810004202#desc_section_2
-Synchronicity-
I nominate montech century 2:
https://www.montechpc.com/century-ii-850w
Dimensions (L*W*H) - 140*150*86mm
Alternatively, you can consider the FSP Vita GM. I'm using it with my Jonsbo D32 pro and it fits without any issue. I'm also using it with a 9070xt sapphire pulse.
Main advantage over superflower is that they offer 10 years warranty.
yukita
Zotac card is 303.5mm x 115.8mm x 55.7mm
I think both of you are right, when i look at Lian Li, I look at side mount PSU config, this cause the GPU length support only 258mm. but if i mount front side. it support 334mm.
For CH260, already mention max PSU is 150. because its side mounted, i think this one no hope unless change PSU.
For Jonsbo, it is stated:
ATX PS2 PSU Clearance:
• When the GPU is installed in the first PCI-E slot of the chassis, the maximum length of the power supply is 150mm, and the recommended length is ≤140mm
