mosmos
High Honorary Member
- Feb 25, 2001
Anyway, I think the Clorox solution is damn diluted. Just curious, those who are using magiclean and other solution one, do you actually use very little solution and mix with the water? Laminate flooring is not recommended leh....i saw the manual, but since somebody said he uses fan to blow, perhaps it's alright, but a bit troublesome....
clorox is best because very little or no bubbles are formed inside tank. Use too much the whole room smells of chlorine.
Recently I tried with blue kiwi clean, because ntuc got sale $4+ only, but the bubbles formed inside tank is a lot and you can even hear it spray bubbles water.
buy.com one?
