SET ST536v6 to bridge mode
geveman
Hi,
I tried to bridge my ST536v6 already, and after that I connect to the router and set to PPPoE. But I am still not able to surf. Are there any settings in the router interface that I also need to set?
geveman
Oh it can work liao.. Thanks. Coz I didn't wait for the comp to restart automatically. But after a while the connection went off. dunno if it's my connection problem. Thanks for the help
geveman
Anyone faces the same problem? I managed to bridge it, and also got my router working after setting to PPPoE, but somehow the connection went off after around 15 mins, and I cannot get it connected again.
Could it be my router setting?
arcturuz
Successfully converted by ST536v6 to bridge mode using the residential CD and tested using the manual connection.
Need to clarify a few things,
1) I have not bought my wirless router yet, does that mean that I have to dial the manual connection to connect to the internet for the time being? Cos I even when the lights on my modem are lit, I can't connect to the internet unless I dial the manual connection.
2) I can't access the the Speetouch Lan homepage anymore a http://192.168.1.254/?
3) After I have bought my wirless router, will it be like before, when I can just access the net without dialing the manual connection?
Sorry cos I'm totally noob when it comes to such stuff. Thanks.
liangtam
You don't need to bridge it when you dont have the router yet.
friendsbyfate
ok.. i need some help again? my linksys router is very slow.. even if im accessing the 192.168.1.1 page.. my internet is very laggy and it even disconnects when my sister uses her laptop to connect to the wireless network.. my router version is 7.. and i tried looking for firmware upgrades from the linksys website bt found nothing.. is this a problem with my settings? my fren told me to change a new router..
Arucard
Guys I flash to the latest firmware , then I set it to bridge mode then connect to my DGL 4300 , I go status in my DGL , the page keep restarting , can't connect , then I plug back my 2wire 2700HGV-2 , suddenly I cannot log into my MDC page to change to bridge mode, wtf is wrong man , i tried reseting the system password , no use , please help man , now my DGL 4300 sitting there doing nothing , was okie one previously with my 2wire , now like that :s27:
Arucard
At last set up my ST536v6 with DGL 4300 with no problem , but now my 2wire cannot access to MDC , wth man , i tried the password 2wire , don't work , what is wrong man? before that i can access to the MDC
Please Help me....
Hii,...Guys...
i also usin the speedtouch modem...535V6.....
recently i bought a Wireless Roter ASUS W520g...
the problem is.. i cant like this 2 device connecting together..!
i had it try it out in the brige ....
and i'm usin windows vista...
So.. do i just download the ISO and install ..?
or Flash the ADSL modem...?
can anyone help.,..?
thanks
with regards
ah_jie1989@hotmail.com
Please Help me....
Hii,...Guys...
thanks
with regards
alf1974
Hii,...Guys...
when did you get the modem?
I just got mine last week and it worked with my netgear DG834G without any problems.
Remember to disable DHCP on the router and let the modem do the IP addressing.
oky.guna
cannot set ST536v6 to bridge mode
Seems my modem was password protected. Seems Singtel set this password
yyD70S
Bridged Mode
Still have problem getting the modem to bridge mode...
wizard does not restart when pc reboots...
WOULD buying a new 2-in-1 modem-cum-wireless router be the best way ?
(of course, it means spending money)
If so, which is a good (ie, reliable) wireless G modem-cum-wireless router you guys recommend?
THANK YOU.
liangtam
You both need to read the thread leh.
The password is mentioned, besides, there are a few more methods available, some fast and simpler, the other more difficult.
yyD70S
Noted.
Thank you. Will try the CL method.
BTW, does getting a gateway (2-in-1) be a better solution?
sigh
Just got my ST536v6. It seems quite intelligent and friendly.
When connecting directly to a PC, it will ask for userid and password.
When I connect to my Dlink DGL4300, it connect seamlessly.
No need to make any settings change at all.
Finally retiring my venerable 8-yr-old Speed Touch Pro.
Anything I should be mindful?
