[Mac 101] Ask your questions here!
PetPet
Moderator
Moderator
Anyone know what model of air cooler to buy for macbook. there is so many brand out there, not sure which one is good.
don't bother with laptop coolers.
As long as your laptop isn't shutting down, it isn't overheating.
thechariot
RAM? HDD? SUPERDRIVE? LCD? KEYBOARD? TRACKPAD? BATTERY? which one?
keyboard and the bezel...
i wanna do something like this..
n0d3
Wrong, they just swapped the MacBook Black top panel/keyboard onto the MacBook White. Both models are discontinued.
thechariot
so there no local shops here that sell the spare parts uh? :o=:p
even the keyboard keys i dun mind.. i found one online but i just wanna know if i can get it locally too..
n0d3
If you walk around SLS, you MIGHT find some spare parts. Otherwise try MUGS (macusersg.org) to try to buy some faulty units for the parts. I don't think it's worth the effort though IMO.
thechariot
thats why i just wanna get the keys.. heheh.. anyways, thanks for the info..
momojay
hi,
can anyone advise how come i cannot get a copy of the email which i had sent through my iPad in my "sent" or "outbox" folder?
is there any setting that i could have missed out?
thnx!
renfred89
i discover most of my frens' macbook already very heated after some time. Mine too face the same problem
I use my macbook to convert videos to suitable formats for my ipod touch. So when its converting, both the cores of cpu are 100% utilized. Therefore the internal fan turn until like siao. I'm so afraid my processor will get burnt...
PetPet
Moderator
Moderator
Well you have will to understand that Apple's MBPs are designed using aluminium and acts as a huge block of heat-sink. Now, if it heats up to a certain point the fans in the laptop are designed to spin up to 6400~rpm to cool the components.
Should things get a little too hot, it would shut down to prevent damage to the components.
KiraX_19
does anyone knows is it possible to use my 21" imac as a external monitor for my another desktop setup? tia
iseelamepple
Only 27". Unless you go other screen-sharing utilities which use the network to extend. Not sure about using as main display.
flashd3vil
Hard Drive Help
Hi Brothers and Sisters,
I own a Macbook Pro 15" and would like to have a Hard drive upgrade.
I'm actually concern about the 2.5" Hard Drive(WD Scorpion Blue 1TB)
that I'm looking forward to upgrade, will it fit into my MBP?
From my understanding, there is two Thickness of 9.5mm and 12.5mm (correct me if I'm Wrong). Please Advice if a 12.5mm 2.5" HDD will fit?
Thanks in Advance!
fragment
sup people. since the new mbp's are out. im on the old mbp, is it possible to send to upgrade to a i7 core?
leinad
Thanks in Advance!
The 12.5mm will physically fit, but you will obstruct/block the air hole and that will lead to the hard drive failing much faster than intended. So no, please don't try to squeeze in the 12.5" drive - the housing wasn't designed to support that.
/Dan
tamago_
Deluxe Member
impossible. the components are totally different, except maybe HDD & RAM only.
FLiNcHY
are there are technicians or stores that can help me put an intel x-25 ssd drive into an Imac i7?
I'm thinking of getting one but i hate the 7200rpm drive in there and the fact that apple does not offer an SSD option
Reading the macrumor forums, it is possible to DIY and install an SSD drive on your own, but I don't think i'm technically proficient enough to do it
Would Epicenter be able to do it for me for a fee?
