Your cable management looks pretty neatmost of the wires arn't conspicuous at all.. lol
initially was looking at the hades or the CM690II advance, kaixax reco the k62 and i look it up in the net. was really interested in the red internal 1, but i guess thats for euro shipment.
a good casing indeed, only drawback for me is tat its damn heavy. if i need to reorganize my room again, tats it man..
haha... go steal then got already lor... haha
j/k j/k..
your front panel connectors can go under mobo and go through cpu hole... I know k62 front panel the wires are short.. yeah? so if can then try going under mobo.. cannot then.. go from gfx
SATA wires just go straight to the right into cable management hole... since they are all facing that way right? :x
USB also go by gfx route... if can.. :x
i just find the sata, front panel wires dangling down from the mobo into the cable management holes below very... 礙眼... cant think of a english word for that XD
AND..... GET A 3RD PARTY COOLER ALSO!!! xD
Do you even need the ODD? if you dont can just put away.. when you need it then just plug in manually...![]()
Yours? It horrid! i see ghost wires flying all around the place!!! XDXDNever comment on my cable management!!
@Bleed, I love the coiled Intel Stock cooler wires. Just realised it.
eyesore right? juz imagine i see that everyday.... must really tahan till aug, coz i juz bought a speaker. when i buy the rig, i already need to skip some meals.. if gonna upgrade some parts, i think i need to eat grass liow... lol.
anyway dirt 2 was awesome..
Just need some info from K62 users; fans' dimensions
Rear =
Top x2 =
Front =
rear 120mm
top 140mm
front 140mm
tyvm, kai
EDIT, is it possible to mod the front to a 200mm
updated already.
if i want to change my cpu cooler and install a side fan, is it possible? let say cpu cooler = prolimech..
now got free 1? hehe jk. now no budget lah bro.. need to stick to stock 1st. if monday tio toto then confirm get good 1s. hehehe.
with stock i guess its better not to oc right? guess i won't be touching those bios setup for now..
