http://korntrading.blogspot.com/2011/12/saycool-a710-7-tablet.html?m=1
Hi guys , how about the above tablet? Saycool.a710 ...looks promising and tempted to get one...
anyone using this tablet? need some reviews on it...
I have all the common tablet sizes:
3.5"- iPod Touch/iPhone;
4.3"- SmartQ V50;
7"- Galaxy Tab;
8"- Onda VI30;
9.7"- IPad
If u only intend to buy 1, I recommend getting the 8" 4:3 size. It is much better for reading, photos and surfing. Even for videos, the size is the same as for the 7" except u get black bars. Much handier and lighter than a 10"
The 8" are around 799-899 rmb and the 9.7" are 999rmb so I feel 9.7" might be more value. The teclast a10 also has full usb port, not micro and also ips. How long does it take for sgshop to ship to singapore from the time you place an order? Anyone know??
I have a tight budget so going for the best value for money tablet, which so far I feel would be the 999rmb 9.7". But by march, maybe the price different alr.
Onda Vi30 delux just released another upgrade on ICS
ONDA
Jan 18 2012
i owned a vi30 deluxe but revert back to 2.3.4 when i tried the first ICS on vi30... this time i wait a while before i upgrade
Thks very much for the heads-up. I just downloaded the older version yesterday!
Prob is I can't read the Chinese instructions so I hv no idea how to do the update. Would u happen to have English instructions or a link? TIA
Just scroll down to the bottom
The version 4.0.3
To flash, u unzip the downloaded file
Double click load the image file and click program
On the tablet u need to power down and power on holding the home key down as u power the tablet on
Thks. Still not very sure. Do I run/install the exe file on my PC with the tablet connected through usb? Will prob wait first - dont want to risk bricking the tablet
Hi
Yes. U run the exe
The exe will then be like a file manager
From there u choose the image file
At this time u power off
Connect USB then hold home and power up
Note even if u click to program it will update only after u power up the tablet.
Take note also it will minimize itself
Just look for it at task bar. Just don't pull the USB cable
After reading many reviews and comments, I am considering n7a or g2 for 7", onda vi30d for 8", and teclast a10 if I feel like buying 9.7". However, now no $ so I am waiting till maybe march. So just wondering, will the tablets be oos by then or maybe replaced completely by newer and better products? Heard that newer processors coming soon...
2) Can buy tablets either from sls or through sgshop, so which will be better for 1st time buyer? sgshop will be cheaper but need to wait dunno how long(2-4 weeks)??? SLS seems very scary, co many ppl con by the sellers. Any suggestions?
If u intend to wait till March, wait for the Rockchip RK30xx dual-core Contex A9. N7A has ended production. I'm expecting g2 to drop till around 499-550 RMBCheap 9.7" will be a better buy compared to 8", that's if u don't mind the size and weight.
Sgshop takes about 1 week IF the seller shipped fast and not during the Dec and CNY holidays. SLS not scary lah, just annoying to me lol Merimobiles, MP4nation can consider also. Pandawill and Ownta (look for coupons) ONLY if they are cheaper than Taobao+agent fees/shipping.
Yes. The Onda Vi40E kinda good, but I'm really torn between Vi40E and SXSE Smart S11. From what I gathered:
Onda Vi40E
Bad:
Battery not very good. About 4 hours usage. 6500mah
Screen not perfect, forum say some white color defect
heavy (690g)
Good:
Better brand, better firmware
Cheaper
Merimobiles has promotion
Smart S11
Bad:
The brand is less well known
Slightly more expensive (but the 16Gb, battery, and 10pt touch screen totally worth it)
Merimobiles not selling (not sure why). Hence must buy through agent. More troublesome if had problems.
Good:
Good quality screen
10pt touch screen
bigger battery. 7500mah. Sanyo brand
Lighter. only 545g
Firmware wise, android 4 really had problems. Even big brand like asus, samsung are late releasing the firmware.
6500mah only lasts for 4 hours?![]()
That's what the ppl in forums said. Also, 6500mah is based on Onda claimed. Teardown pictures shown the battery had no model number.
I went to view the sgshop and found out that there's a vendor from taobao selling onda vi40 at about 280SGD for a 16gb. Is this site trustable?
Onda Vi40E
Bad:
heavy (690g)
Good:
Cheaper
Smart S11
Bad:
Good:
Good quality screen
10pt touch screen
Lighter. only 545g
Another one u can consider is the Cube U9GT2. About US$50 more than the Onda but decent reviews and battery supposedly better
Yes. I have considered this in the past as well. But the missing hdmi is a turnoff, also the A10 cpu supposedly better at decoding various videos, as it has hardware support for 1080p (even 2160p) videos
