[Mac 101] Ask your questions here!
negativzero
just received my order of refurbished macbook air (2011) 2 weeks ago, does it qualify for the free upgrade to mountain lion ? Cant find any information on refurbished set in apple website.
Probably not. The keynote did say NEW Macbook, not refurb. But no harm giving Apple a call to find out.
lym_d
Yes won't have any snapshots of the VM. which means u can't pause it. you got to shut it down.
However it's at least better this way for me. up to individual preferences.
Yes creating bootcamp and doing an image via parallel also uses space. :)
To me the downside about bootcamp is u need to commit the space you set aside for windows from the start and to make changes(OSX to recover space from windows, you probably need to wipe everything and redo).
shawn_sboi
Yes you are qualify for mountain lion :)
When mountain lion is released. There will be a link for those who have bought from apple store/retail store to register. No worries for you.
shawn_sboi
Nope. To wipe space is easy too.
Go over to your Windows 7 and open the disc management or right click 'my computer' and click managed.
Shrink the bootcamp drive. that empty space you can merge it to HFS+
angelinetan123
anyone knows whther is it the battery of mac book pro is good??
On the spec it wrote 7 hours..but does that mean standby?> so let say if I watch movie, battery may decline to 2 or even 1 hours..
Can also pls gimme some comparison for battery life bet mac book pro and normal window laptop.
Much appreciated.
Thank you :)
shawn_sboi
Much appreciated.
Thank you :)
7 hour with low brightness, bluetooth off, running using integrated GPU. yes 7 hours u can achieve.
cracker
Thx.... lets see how it will turn out when it is released.
angelinetan123
Hi all,
will macbook pro with corei5 be good enough for work/school etc?? or need core i7? what is the main different actually>
thx all :)
limpe84
Hi all,
thx all :)
i7 if you need to run processor-intensive programs like movie-editing software or photoshop. If it is just for normal word processing / surfing and the like, i5 will suit your needs just fine, and you will likely see very little benefit from upgrading to i7.
Try this article. It is a year old, but the advice inside should still be relevant. :)
MacBook Air 2011 i5 vs i7 – Is the upgrade worth it? | Mac Crazy
davidktw
Hi all,
thx all :)
Interesting question.. :) But I'm sure even when it's time one is using Intel i100 with 100 cores running at 10Ghz, someone will still ask this kind of question. keke
I would like to provide the following answer:
I use a Pentium laptop running at 1.7Ghz for work and school, "not very long ago" :)
It's all about purchasing power and expectation.
Farisworld
Hi guys,
I am looking to purchase MBA but idk 128gb or 256gb drive because I am on a tight budget.
My school requires us to use windows so they will install bootcamp and windows7 in it and they want a minimum 80GB on windows. I don't know if it is sufficient or not.
Do you think its possible if I save my data for school on external hard drive instead. Would this make room for other programs?
Because I generally use my laptop for browsing purposes, in school for presentation, doing programming, websites and thats all.
Would 128GB hdd be sufficient for bootcamp and with another help of HDD (for keeping school files)?
I kinda need answer asap :(
shawn_sboi
Hi guys,
80GB? what course are you in.
I feel that 30GB is enough for windows if you are going to use mac often.
128GB - 12GB(mac osx) = 116GB left.
If you are going to make 80GB for bootcamp. THen why get a Macbook air?
HI,
Is there anyway to check, where my HDD space used up by what? Coz its getting out of space, And I dont know what costing so much space ..
Farisworld
Have not started the course related yet, i went to the helpdesk and I asked him. He said 80GB minimum for windows, I don't know what crap hes talking about.
I know right, but is there a way to actually allows me to view my files in Windows from the MacOS itself?
davi502
You can either install Paragon HFS+ or other free tools like HFS Explorer (read only)
limpe84
Yeah. In OSX, click on finder (the top left hand corner)--> preferences --> check the show hard disk box. This will show your drives (including boot camp partition) on your desktop. You can then click on the icon and view the files in that folder.
If you need so much space, may as well go 13" macbook pro. That's $1500 after edu discount, then maybe see if you want to replace the ODD with a small SSD (but together with parallels and windows, expect the final cost to reach around $2k). :(
If this is the case, then may want to consider just going for a cheap windows laptop that comes bundled with office.
