Prebronzer
- Jul 3, 2012
Battery HB3G1H
Where an I buy a Battery HB3G1H for My Mediapad ?
Thank you
Thank you
Anyone know where to buy the screen protector and casing?? Really hard to find. Everywhere people are just selling samsung galaxy tab casing and screen protector.
hi ..may i know where can i buy Huawei Mediapad ?
Also , on the USB OTG , anyone uses it to connect to the mobile broadband usb stick to connect to internet if tablet does not comes with 3G function ?
Cool. Nice cover. Wish can get one like yours. How long did the delivery take?I got my casing from china huawei online store for around sgd 40 plus shiping, it fit realy nicely with mediapad
I must agree with you. Good buy. Only hard to find casing.any bro facing the below mentioned 2 problems?
1. Wifi auto off
2. brightness auto off (screen dim need to go setting and touch on the brightness to "brighten" up the screen)
If yes, how you solve it? thanks (I had upgraded from HC to ICS)
p/s: I must say that this is really a good buy when I bought it at 299 in Best Denki sales...
Maybe software issues. You might need to reflash your ics rom again to eliminate the problem
Installed this, screen is smoother, and Antutu is 6000+ at 1.5GHz.
Just checking if anyone has tried this?
[KERNEL][ICS 4.0.3][07/31/12] Mediapad EX - xda-developers
-updated to newest stable kernel base (3.0.38)
-overclocked CPU up to 1,5 Ghz with oced BUS/RAM on highest steps, boots with 1,2 Ghz
-complied with Snapdragon optimized flags (-O2)
-optimized CRC32 and ARM RWSEM Algorithm
-CPU-supported unaligned accesses
-SIO scheduler
-XZ Kernel Compression -> smaller kernel size
-some debug code disabled
-arkusuma's touchscreen driver mod
-JHASH v3
-KSM and Autogrouping enabled by default
-RCU with Priority Boost
-Init.d support
How do u flash this kernel? How to get to fastboot n flash?
Does this kernel solve the random reboot problem?
