Huawei Honor U8860 non camera Users come in
3dwintan
You can actually open the runme with notepad and try to manually run the commands inside. I suspect it is waiting for your device. I got this before and got it fixed when I got the adb properly installed. I uninstalled the existing huawei devices and replugged the device and all the adb interfaces are recognised. Only then the runme works
Ok I managed to root my huawei ...however, on my other computer which is not on 64bits windows.
Suspect that could be the problem cos I tried many times on my 64bits windows always cannot....once i use my other 32 bits comp...first time ok liao....
aztech44
managed to get my phone root . thanks :) . however i would like to know how do i get my phone to un-root back and sorry to ask this sensitive question, after root, what can i do with my phone and how do i get paid apps for free?.:s34:
DesertStrike
blackmart alpha, and u do not need root to do that
Tomatokid
i am looking for the normal sized battery.
if you sell, pls drop me a pm on price and location to collect. tq.
Huawei Honor u8860 Ultra-High Capacity Battery 3600mAH (HB5F1H)
Ultra-High Capacity Battery | Singapore Huawei Honor U8860 (Case & Protector) Specialty Store
If you are looking for a quality battery that provides maximum standby and usage time beyond the stock battery, then the only battery that can fulfill your requirements will be this ultra-high capacity battery.
This battery has a ultra-high capacity of 3600mAH, which is almost double the capacity of the original stock battery that comes with the phone, and provides extended usage of about additional 60% to 90% more than the original battery.
To achieve the ultra-high capacity, the thickness of the battery is about 2 times of the original battery. As such, it also comes with a back cover for the phone to accomodate the extra thickness of the battery.This battery is extremely handy when you go outfield for a couple of days as the phone can last longer without have to recharge.
Specifications:
Model: HB5F1H
Compatible: Huawe Honor u8860 / Glory M886
Capacity: 3600mAh
Cell Type: Rechargeable Lithium-ion
Package include:
1x 3600mAh Ultra-High Capacity Battery
1x Back Cover
Available for purchase online at corisen.wordpress.com or at Magic Cube retail shop at Shaw Towers #01-18 (100 Beach Road).
Opening Hours:
Mon-Sat: 12-8pm
Sun: 12-5pm (closed on PH)
Thanks.
aztech44
Hey shadow. I did re-flash to unroot back my phone. However after doing it the superuser did go off and i check the root checker its saying that my phone has successfully unroot. The problem happen right after my phone restart the superuser still appear. How ah? I wanna get rid the superuser.. I also did factory reset yet it Still appear :(
Corisen
Huawei Honor Battery
Hi, if you would like to get battery with normal thickness, you may visit the Magic Cube retail shop at Shaw Towers #01-18 (100 Beach Road) to purchase it. I've just stock in some batteries today.
Opening Hours:
Mon-Sat: 12-8pm
Sun: 12-5pm
Price:
Regular battery: $10 (estimated 1100/1200mAH)
High Grade Battery: $16 (estimated 1400/1500mAH)
Alternatively, if you would like to purchase online, you can email me your phone number, mailing address and qty and I can mail them to you.
Thanks.
DesertStrike
Download ics non camera version, inside there is 2 update file, use the UPDATE_CUST.app
cosmos89
Hi, got a question.
At the lock screen, is it possible to change the icons? What I mean is currently if I move it to the left, it will go to my message, up will enable me to make a phone call.
Is there any way to customize it such that maybe if I move left, it will go to Facebook or somethin?
hermes76
Hi, got a question.
am trying to find out too, like how can we include more shortcuts in the front lock screen
buaypangsai
Hi, can someone teach me how to do screenshots using Gingerbread.
I googled. Need to "jail break" the phone to do screenshot. Is there an alternative method..?
