wongls
- Jan 9, 2007
Which power pack is good for S3 ?
Those casing 2200mHA type..
I'm using Sanyo Enelope 5,000+ (can't remember the exact amount).. Good!
Edit: Sorry, didn't notice you are looking for the casing type.
BTW, anyone experience problem with your S3 not able to read your SD card out of a sudden. But when you put in another SD Card, it's ok. The supposedly faulty SD Card is ok - readable using another device.
, so as to feedback and improve
