Samsung Galaxy S3 - It's Finally here!
jeff79
Code:
http://forum.xda-developers.com/showthread.php?t=2091045
You have to install some program then check the result.. Just follow the step in the link I provided.. =)
Do you mean the emmc app for checking the eMMC type and FwRev? I am reading that thread every few days and did not saw any post on installing app to check the 'update 7' of the firmware.
Appears like all 4.1.2 based i9300 builds will have the fix
eMMC app is not conclusive. Its only VTU00M 0xf1 of a certain firmware date (which cannot be answered by app) that are affected.
Basically not ALL VTU00M 0xf1 chips are affected. Only Oranav test can tell you conclusively if you have the firmware which contains the bug but its a little more involved in you have to flash a kernel to test so some people wouldn't like that.
Laneige
noob qns.
if the screen got burn in marks. can get replacement form service center?
the bottom half (keyboard) got burn in marks.
thx
if exterior = u never use properly
if interior means something wrong with phone n u can argue to get it replaced FOC
be3hive
is burn in mark on the lcd. like those of plasma tv with the channel 5/8 logo.
tot someone might have the same prob .
wolvie77
anyone know of an app that can set lockscreen wallpaper using photos without cropping? i found multipicture livewallpaper but after setting it doesn't seem to work. it still shows the wallpaper i set using samsung's default wallpaper setting.
bhkpop
Code:
The "Sudden Death" issue is caused by firmware on the (16 GB) VTU00M, revision 0xf1 eMMC (Embedded MultiMedia Card or internal memory if you like). Samsungs Kernel Source Code (Update 7) has been identified as the fix. There is still no evidence that the latest sboot bootloader addresses this issue.
I got it from the first post in the thread. Don't know why you are not aware of this so called update 7 if you are following this thread.. Anyway I think I read some post in the same thread that update 7 is where FwRev = 0xf7 and mine is that FwRev after getting back from service center is that.. Just sharing..
Anyway the 4.1.2 will be outhere soon so, just in case you got your device from service center recently and if you have that FwRev, you will be save though you have not update to the latest 4.1.2 :)
Cheers
jeff79
Update:
Just read it that for those that motherboard is not changed in Samsung service center and updated to update 7, the update is indeed from those firmware..
Your eMMC become version 0xf7 is due to change of new motherboard.
Code:
Cheers
That 'update 7' is samsung kernal source code, nothing to do with the eMMC. There is no app to check whether the phone firmware kernal is 'update 7' :(
Saw posts in xda forum that eMMC FwRev 0xf7 is for eMMC made after dec-12. The eMMC firmware version is not affected by flashing of phone OS firmware/rom. Need to change motherboard to get that new patched eMMC firmware version, as there is high chance of failure in updating the eMMC firmware even at the service centre. Some people in xda forum got replacement motherboard with the 0xf1 eMMC.
Seem like the 'update 7' patch will make the phone hang when it encountered the eMMC firmware bug instead of bricking. Reboot to get the phone working.
squeeish
Does anyone have a link to download the latest stock firmware? Singapore-version.. pretty please. Thanks!
triface
nintendo
anyone has issue with sbs transit iris app? It can detect my location but when i click on the bus stop, it does not load the buses available at the stop. Same goes for every single bus stop. Anyone has any idea about it? Used to be working fine.
Nichi
why not use shownearby?
yuanzhe
Just gotten S3 LTE. How do I lengthen the ringing time for the phone? The phone rings for about 15 sec only and the line is cut even though the caller does not cut off the line.
Can I increase the time to say 30 sec or 1 min? I do not have a voice mail service
but has the caller alert feature.
Appreciate any help. Thanks.
Nichi
this one is set by telco and not the phone
