[Mac 101] Ask your questions here!
runforyourlife
Moderator
Moderator
For a big ticket item like an iMac, I would definitely recommend AppleCare. My screen conked off recently and thanks to warranty, they came down to repair it FOC. Definitely will save you a lot of headache down the road.
Basic 27” iMac can more than handle diablo3 on 2560x1440 res. For other more intensive games like darksiders 2 (via bootcamp), you either run it at 1920x1080 (windowed mode) or upgrade the graphics. It is not quite enough to power 27” screen worth of gaming. =:p
Thanks bro.. Plan to upgrade fusion drive n gpu. Getting AppleCare and office mac student n home.
Any place to reco for e purchase? Was thinking of juzz1, and/or wait for it's how maybe better bundles on e custom set...
nakamoto
hello. i have fully charged my mbp, let it to sleep, the next morning, it drops to 95%, is it normal?
s0nics0nic
Hi, can i ask if macbook pro can be used to play diablo3? Or is it not compatible?
negativzero
No i mean u guys mentioned imac can be used, but macbook pro can? It wont be optimal?
If yours is a 15 inch MacBook, there won't be any problems. 13 inch ones will struggle.
Oh and I highly recommend ALL MacBook users do the optibay mod. You will never look back and regret ;)
xjasonz
imac end 2010 user here. i have a bit of problem. I just installed vmware fushion and windows 7. manages to dl bf3 on windows 7. but somehow, it keep showing this when i run the game.
Uploaded with ImageShack.us
how do i solve this problem?
Melimtingnian
Hello people,
I have these following issues with my Macbook. Please do advice me what I can do to rectify/resolve the problems that I'm facing.
1) Blue screen error @ windows partition
- tried to resolve the error but to no avail hence I have decided to reinstall the entire windows OS at boot camp.
2) logged on to Macintosh OS, tried to delete the entire windows OS by re-partitioning it.
- forget my password to authorize the action
- tried to remedy by using 'Mac OS X install DVD' to reset the password
- inserted the 'Mac OS X install DVD' and restart my laptop
- upon boot up, hold onto the C button
brought me to the following screen
waited for a couple of hours, but still nothing happen.
all I could hear was the spinning of the CD for 5-10seconds, then it will start to slow down and eventually stop.
This process keeps on repeating itself.
anyone can advice me on what to do next?
If all else fails, I guess I can only bring it to Apple Support.
Saw Eserve Singapore, and wonder how much would they charge me for this 'consultation'. Anyone had similar experience and care to share how much would I be charged?
Thanks
PS : Mac specs
Model Name: MacBook
Model Identifier: MacBook5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
Sudden Motion Sensor:
State: Enabled
yizhimei
Hello people,
Thanks
PS : Mac specs
Model Name: MacBook
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
State: Enabled
Normally for this case can be either software corruption or hard disk crash. If your computer is still in-warranty, I advise you to send it to repair. If no warranty, prepare to pay huge sum of money. But anyway, all data will be loss.
jupiter12
Will doing the optibay mod void the macbook's warranty?
Kennethzzz
Hi for iMac say if it is still under warranty and it spoil, do we have to bring it down or they will send technician to your home to repair?
B772ER
if you have applecare protection plan and diagnosed as hardware failure, can arrange for onsite tech. if the imac does not have APP, you have to bring it down yourself.
EEXOOO
Hi guys, my iPhone 5 is under first year warranty with AppleCare. Is it possible for me to go over to Apple's service centre instead of Starhub's?
weird
if i were to buy a hdd off shelf (that is not MAC support), do i have to do anything so that i can read/ write to both mac and windows?
davidktw
To be frank, there is no such thing as MAC support for external HDD should they comply with the necessary interface of either USB 2.0/3.0, Firewire 400/800, Thunderbolt, ESATA(require external ExpressCards)
All you need to do is ensure the filesystem is cross platform recognisable between Mac and Windows. For different versions conbination of Mac and Windows, the common denominator is different. But you can be quite safe if you stick with FAT32. This is the lowest denominator of filesystem that is interoperable between Mac and Windows.
Should you decide to use a NTFS driver which is freely available or if you want more performance for a commercial product, you can upgrade the common filesystem denominator to NTFS.
if both your Mac and Windows support ExtFS, you can choose this as your filesystem for your external drive too.
