Official Xperia Z Thread
Drexter
Me too. After many tried also same.
Finally, found a solution: Settings --> Language & Input --> Xperia Chinese keyboard --> Voice input --> Select Off
By uncheck Google voice typing will not solve the problem.
Cannot find Voice input under Xperia chinese keyboard settings
dreamz13
kind enough to recommend a good keyboard that supports eng and chinese typing? prefer one similar to s3 where you can toggle between eng and chinese with one button
if u dun like the xperia chinese which allows u to toggle, u can try smart keyboard too
yhw22
Inside Xperia Chinese keyboard settings, Did u see General settings? It is just below English text input settings.
You will see Voice input and make sure it is Off.
123456tw
have a long scratch at the back of the phone
should i take out the plastic thingy?
wolvie77
Hi! all. anyone using whatsapp & experiencing the keyboard not responding when u launch the app to reply someone. u need to press back button once then press back the contact u wana reply then it wilk work
5408854088
how to remove the blinking light notification ah? imo kinda waste battery sia. also, how to enable vibration for sms/whatsapp? cant seem to figure out. :o
OnLyOnE
I just realized the nfc speaker cannot be use on skype. Or is there something I am not doing...
Dr.Quattro
sometimes i experience that.
At first i thought it was my appblocker causing the problem :s22:
foosdoll
I can't turn on portable wifi hotspot. It seems to conflict with turning on wifi which then tries to search for open networks but all I want to is to make my lte network open for others
