- May 3, 2001
That is exactly what i did salvaging the balun transformer from e rabbit ear antenna and try it with the Clip CD case but somehow receive no signal at all. Suspect it could be balun transformer faulty. juz could like to give it another try with the one in the photo.
If u encounter problem, it's better to replace the older components with newer ones so that at least u eliminate the possibility that it's balun problem rather than antenna design problem.
