Singapore Digital TV discussion thread - all related talk, please post here
pjs
You received these stations from Woodlands or JB?
He says location is JB.
Really interested to know which STB he used.
This will also answer doubts about compatibility.
If he can receive the signals 100% in JB with this STB so can we in Sg.
Brand? Model no?
yiyiday
Hi
May I know details of the set top box u used?
Tks.
Here is the general description of the set top box from from my suppplier (the hardware specification I will post later):
Product Specifications "
1、MLStandard DVB-T2/ High Definition MPEG4 AVC/H.264 HP@L4,MPEG-2 MP@HL
2、Automatic PAL/NTSC conversion
3、2000 channels TV and Radio programmable
4、The maximum speed of the traffic flow of at least 50 Mbit / sec
5、8 different favorite groups selection
6、Fully support to 7 days Electronic Program Guide(EPG)
7、JPEG BMP GIF support,Flesh tone extension,Black/White extension
8、4/8/16-bit OSD with anti-flickering
9、Channel search in automatic, manual and network search
10、Various channel editing function(favorite,move,lock,skip,delete,rename,find,sort)
11、Parental control for channels
12、Plug and Play installation, with an ease to use Menu System
13、Software upgrades through USB/Cardreader
14、Time set by GMT offset automatic and manual,Summer Time support
15、5 event timers,off/Once/Daily/Weekly/Monthly Mode
16、Subtitle support
17、VBI insertion for Teletext,CC and WSS
18、Automatic save for last channel
19、Support Logic Channel Number(LCN)
20、Active Antenna Power supply control"
chakuman
I am actually quite excited for the launch of Channel 8 HD, Suria HD and Vasantham HD!
pjs
16、Subtitle support
Is is this one?. Same specs.:
F5Q HD DVB T2 Digital Terrestrial Receiver TV DVB T2 Tuner SPC 0550 | eBay
yiyiday
Brand? Model no?
Yes, at JB (Tebrau Area).
Actually I made myself a guinea pig for this DVB-T2 set top box. Just to prove it is working before I can sell to others.. :s13:
yiyiday
Is is this one?. Same specs.:QUOTE]
You can find many model of DVB-T2 set top box on the market. Mostly manufactured by one manufacturer, the differences are only the front panel and the look.. the backside all the same because it is the same pcb. This manufacturer is the ODM for all other brand, I get it from them directly.
pjs
Can you try to see if u can receive T2 signals from Batam.
They have following on T2:
Indosiar, SCTV, MNC TV, Global, RCTI, Trans 7, TRANSTV.
Indosiar and SCTV have live EPL on some days.:D
I can receive TVRI 1 & 2, MNC ,ANTV,RCTI and Metro on DVB (T1) but my old Humax STB cannot receive DVB T2.
yiyiday
Here is the specification,, I can't digest all but I just knew that it work!!! :s22::s22:
Hardware Specification
Chip & Board Main Chip MSD7816 (LQFP128) /550MHz
Flash 32M bytes
SDRAM DDRII 32M*16bit*1pcs@1066MHz
System Crystal 24MHz ± 20ppm
TUNER Rafael R820T
COFDM Demdulator MSB1236
Embedded Audio DAC Internal
Audio Amp DIO2112
USB 2.0 Embedded Host
Video DAC Internal x4
PCB 2 layer FR4
Front Panel LED spec Power Indicator (LED): (Standby, Lock)
Rear Panel Tuner RF input connector IEC-162-2( Female)
Tuner RF Loop through connector IEC-162-2( Male)
SCART Connector TV Scart(CVBS,RGB,L/R) x1
HDMI Output A-Type HDMI Connector x1
SPDIF Coaxial x1
Power AC100~240V 50HZ
Basic User Interface Features (common features)
Menu OSD Load OSD setting default Set Menu OSD/Subtitle to default value
Basic Features Welcome page (installation wizard) auto scan, Channel automatic search at first installation
Installation Aerial Adjustment Channel NO.,Tuner Power
Auto scan Scan mode(all)
Channel automatic search at first installation, defined in welcome page
Channel Scan Scan Band, Channel No., Frequenecy, Bandwidth
Program Management TV/Radio Channel List
Channel Num. 200
Channel management Favorite/Move/Sort/Delete/Skip/Lock/Edit
Sort sort type: Default/Name(A-Z)/LCN
Recall Recall last selected channel
Channel Bar Display Display: Channel name /date /time /Channel number/TV&Radio icon/EPG icon/
Channel information display while channel change in full playback window Display: Channel name /date /time /Channel number//EPG icon/TTX icon
TV System Display Mode Auto / 480i/p, 576i/p, 720p, 1080i/p .
Aspect Mode 16:9/4:3LB/4:3PS
Video Output RGB/CVBS
Digtal Audio Output BS Out / LPCM Out
Startup Startup screen Specific customers logo for Video/ Radio
Startup Channel setting bootup with last watched TV or Radio channel/ customer pre-set channel
Time set Time set by GMT offset (get from stream + offset user set)
Time set by Region (get from stream + Region's offset)
Time set by user
Timer Event Timer Share with EPG
Timer Mode 1. by Once/Daliy
Timer Service "1. Channel: change to user pre-defined channel on user defined time.
2. Record Booking.
System should return to original status while the timer finished."
Wakeup Channel User can select in channel list
Wakeup date and time User can input date and time
Tools Default value Load default value
USB Device User can play picture/audio/video
Remove USB device safely User can remove the USB device safely
Software upgrade "1. OTA
2. USB"
System Spec
"DVB-T2
" Terrisal Receiver Standard DVB-T2/T(EN 302755/EN 300744)
Constellation QPSK / 16QAM / 64QAM/256QAM
FEC 1/2, 3/5,2/3, 3/4,4/5,5/6
Guard Interval 1/4, 1/8, 1/16, 1/32,1/128
FFT Mode 2K/ 8K/32K
Support Single and multiple PLPS YES
Video Decoder MPEG-1/2/4 Video Decoder; H.264 Decoder;VC-1 Decoder;Real Media Decoder–Optional
5. JPEG base-line, progressive
Input Rate Max. 80Mbit/s @ MPEG2
Max. 60Mbit/s @ H.264/AVC
Min. no limitation
Video Output SD/HD DAC
HDMI 1.3(video format default @ Auto), support HDCP
SCART X1 (TV : RGB & CVBS; )
Dual Output (SD(CVBS) + HD(YPrPb, HDMI))
Display Resolution 480i,480p,576i,576p,720p_50Hz,720p_60Hz,1080i_25Hz,1080i_30Hz, 1080P_60Hz
Aspect ratio 16:9 wide screen, 4:3 letter box, 4:3 pan scan
Audio MPEG Decoder MPEGI layer1/2, MPEGII Layer II
AAC Decoder AAC LC
HE-AAC v1/V2 (2-CH), 5.1 down mix 2 ch
HE-AAC v1/V2 (5.1 CH)
Dolby Digital AC3 5.1
DD+ 5.1
MP3 Decoder YES
WMA Decoder YES
IEC-958/1937 Output PCM/ Bitstream
"Show OSD
(Menu/Subt/Txt)" Color depth 16-bit
Resolution 1920 X 1080P (HD-OSD)
Multi-Media Features
File system USB Disk " - FAT12/FAT16/FAT32
- NTFS(license)"
Length of file name Long file name
Multi-partition Max 15 partitions for each device
Container TS File name: *.ts /*.tp/*.trp
Video codec supported:MPEG1/MPEG2 MP@HL/H.264 HP@L4.0/
Maximal video resolution:1920x1080x30
Audio codec supported:MPEG layer 1/2/AC3/AAC
MPG File name:.mpg
"Video codec supported:H.264 BP/MP/HP;MPEG4 SP/ASP,Xvid
MPEG2 MP@HL"
MP4 File name:.mp4
Video codec supported:MPEG1/ MPEG2 MP@HL/MPEG4 SP@L3 to ASP@L5/H.264 HP@L4.0/ H.263/Xvid
Audio codec supported:MPEG layer 1/2/AC3/AAC/
Subtitle:Yes
AVI File name:.avi
Video codec supported:MPEG1/ MPEG2 MP@HL/ MPEG4 SP@L3 to ASP@L5/H.264 HP@L4.0/ H.263/Xvid
Subtitle:Yes
MKV File name:.mkv
"Video codec supported:H.264 BP/MP/HP;MPEG4 SP/ASP,Xvid;
MPEG1/MPEG2 MP@HL/ MPEG4 SP@L3 to ASP@L5/H.264 HP@L4.0/ H.263/Xvid"
Subtitle:Yes
OGG support OGG format Partly Compliant - pls provide comments
OGG playback list User "Up/down/Page+/Page-" to move highlight
Play mode select: repeat one/repeat all/repeat random/repeat folder
Basic playback operation Play/Pause/Stop/goto/Next/Previous
JPEG Support JPEG/BMP format JPEG/BMP/PNG
"JPG : baseline max resolution 16384x12800
JPG : Progressive max resolution 1280x1024 PNG/BMP : Max 9600x6144resolution "
JPEG playback list User "Up/down/Page+/Page-" to move highlight
Play mode setting: Time interval(1-10 secs),,
Play/pause
Basic playback operation Picture rotation
5 methods fade in/out in slide show mode
Rotation(90,180,270)
OSD infor "exit"
Zoom function Zoom in/out
Multi-Picture Preview 9 pictures
Trick mode Playback file Pause/FF/FR/
Playback setting Real resolution / full screen
Adavnced Features JPEG slide show+OGG playback OGG playback at background, while JPEG slide show
PVR Features
USB disk File system " - FAT12/FAT16/FAT32
- NTFS(license)"
USB disk speed auto detect "1. Write Speed <Current stream BitRate*1.2 -> No Record
2. Read+Write Speed < Current Stream BitRate*2*1.2 -> No Time-Shift."
USB disk check Every times plug USB disk will delete all un-used files
Multi-device ATA&SATA / USB disk
Time Shifted Recording Time shift
User operation User operation on Banner (Record file/Time Shifted Recording) Play/Pause/Stop
Fast Forward/Fast Backward 2/4/8/16/32
Slow Forward 1/2, 1/4, 1/8
Limitation: Recorded scramble file playback: Only support play/pause/FF
Reord file management Lock/Delete/Rename Lock/delete/rename recorded files
Full screen playback Select recorded file and playback on full screen
Recording and full screen playback recorded file at same time
Browse recorded files Press "Play" to preview files
Press "OK" to show the first picture of file
Recorded file information Display Record date/duration/channel name
Default files display sequence Sort by Date and time with descending sequence
Hard disk operation Hard disk information Display:Free size/Used size/Timeshift reserved size/System reserved size/Total size
Partition support split partition
Format Fast format
Tools USB disk file manager with PC tools USB disk have self defined file folder to save recording file,
tuckloong
wow how much for one?
yiyiday
cannot lei... maybe too far away, btw where is your location? I can only received very blurr image on analog signal for sctv and rcti.
pjs
Location: Eastcoast Singapore- facing Batam. using powered indoor antenna.
Can receive SCTV and RCTI analogue with simple wire antenna.
SilveR1_09
Hi there,
Saw this post of yours and me interested.
I have been trying to get T2 channels from Batam as well, but to no avail.
Only managed to get all Singapore's T2 channels.
Antenna: HDB rooftop MATV
STB: DVB-T2
Below is the information I got from their InfoComm Ministry:
DVB-T2
UHF50 - 703MHz - Emtek Group (SCTV & Indosiar)
UHF44 - 658MHz - MNC Group (RCTI, GTV, MNC)
UHF46 - 674MHz - TransCorp (TransTV, Trans7)
The latest I heard from them, MNC Group & TransCorp are live.
Emtek Group having technical problem with their transmission tower and are off-air at the moment.
You able to receive the Indo DVB-T channels from Batam, how's the signal strength and quality like? Still on-air these channels?
I knew they ran DVB-T trial some time back. Didn't know the DVB-T channels are still kept alive.
Care to share the frequency of their DVB-T channels, please?
On a separate note: For analog channels, I'm able to receive SCTV & RCTI (viewable). MNCTV, GlobalTV, TransTV (cannot make it).
Regards
pjs
Hi there,
STB: DVB-T2
DVB-T2
Regards
All T1 channels are currently on: Main freq 690MHz- Ch48 labelled as TVRI
TVRI-1 TVRI National
TVRI-2 TVRI-Riau Kepri
TVRI-3 RCTI
TVRI-4 ANTV
TVRI-5 Trans
TVRI-6 MetroTV
Dont know signal strength (TV doesn't show) but pictures are sharp (576i).
Sometimes when reception poor- no picture on some of above.
So being digital, its either sharp or none.
I can receive most analogue signals of varying strength, some need booster. but RCTI and SCTV are clearest.
Hope that helps.
BTW may I know whats your dvb-T2 STB?
SilveR1_09
TVRI-3 RCTI
TVRI-4 ANTV
TVRI-5 Trans
TVRI-6 MetroTV
Hope that helps.
Thanks for the channel/frequency info.
Yup, those are their 6 DVB-T channels when they were ''trialling'' it back then.
Signal strength would have to obtain from your HUMAX controls since we're using STB. If using iDTV, then the TV controls would show it. (Both cases, usually the ''INFO" button)
For analog, RCTI & SCTV has the highest transmission power amongst all their channels it seems.
Your location is prime for receiving their TV signals. High floor, have a clear view south I guess?
My set top box is Getmecom HD9 DVB-T2.
pjs
Unfortunately mid floor and also not facing north. If facing sea (south) it would be perfect. But then again not missing much except for occasional EPL or Champions League matches. Movies are old and rest of progs in Bahasa Indonesia.
SilveR1_09
If you're a sports junkie, these might be of interest.
Serie A & Coppa Italia: TVRI
EPL, FA Cup, Capital One Cup: SCTV & Indosiar
La Liga, Copa Del Rey, DFB Pokal: RCTI
Ligue 1: B-channel
Bundesliga: Kompas TV
UCL & Europa: SCTV
World Cup 2014: ANTV & TV One
MotorGP: Trans7
Formula 1: Kompas TV
That's Indonesian set? Bought in Batam?
Cheap. <$40
Ya, Indonesian set. Bought in Jakarta. However, MIC still I believe.
Yes, around $40.
