Air purifier?
WussRedXLi
Make Your Own Air Purifier For 200 RMB? Really? Really. » MyHealth Beijing
So yes, it makes perfect sense that a do-it-yourself combo could work — and it does. I tested the smaller Original model in my three small rooms, 10-13 square meters in size, overnight with the doors closed. And this little guy did about as well as any other machine I’ve tested: PM1 levels were 91% lower than the outdoor air, and PM5 levels were 95% better. This was on its lowest speed setting, which was tolerably loud but certainly noisier than my usual Blueair settings at night. In my most recent testing of Blueair, IQAir and Airgle, I got bedroom results of 88-90%. For small rooms, this little HEPA filter was at least as efficient as all of the big boys.
His newer machine, the 450 RMB Cannon, was designed for bigger rooms, and I think that also could work well in theory, since it’s the same HEPA filter on a stronger fan. I wish I could share hard data with you, but honestly I didn’t get a lot of data points on this machine, mostly because it was just so darn noisy that I didn’t want to test it any more in my living room. Even at the lowest setting overnight, it was much louder than normal background decibels from my current IQAirs. For me at least, that’s a non-starter as an option. Thomas openly admits that the Cannon is a bit loud, but it still is effective even on low settings (see the graphic to the right).
Akai Ryu
Just get Samsung AX40, now dropped to S$285 incld EMS shipping. :crazy:
Overkill for even Pasir Ris MBR. Can mian qiang use in living room too.
Powerful - 350m^3/hr. True HEPA. Quiet. Cheap. V energy efficient, 34W for 350^3/hr airflow so great for extended 12hrs/day operation. Even the improved spec Honeywell HA170 uses 85W for 250m^3/hr.
Where to get man?
No need to complicate things. :crazy:
Thinking of getting another A50 for the filter...change new ones for bedroom then old for studies....use 3M coz I stocked up fair bit last haze....and to extend hepa and protect ac...k I am complicating things...latest is more plants at home....esp palm and peace lilies
WussRedXLi
Too bad the 3M Filtrete no more usd4.97. Never dropped for quite a few months. So can't recommend to others who don't exactly have a budget for an air purifier.
This mega pack is just usd49.89. It's 4 pack of 30 by 60 inches.
http://www.amazon.com/Filtrete-Allergen-Defense-30-Inch-60-Inch/dp/B0002YPYV4/
Compare that with our local and AMZ's 15 by 24 inches, at S$17.90 and usd4.97 or 7.08.
It's 20X more area, which makes out to be 49.89/20 = usd2.49 each.
But ugh, they have to pack it so that one dimension is 17.5 inches, so no FSSG. And I don't think the CSO would entertain waiving off coz packing dept most probably won't risk folding it. (which seriously is no issue)
17.5 x 14 x 5.5 inches
mosmos
High Honorary Member
WussRedXLi
:( if from korea 60hz power, i think you should worry this one if want switch on 24/7~
Electricity World: 50HZ Appliance & 60HZ Power Supply and vice versa
No issue.....I was concerned with this and did googling before deciding to take a risk to get it coz it should not present any issue. Also tested many times 24/7, full speed.
The electronics are happy. There is no transformer in the appliance (SMPS), the "issue" is with electric motors esp like fridge compressors. There are no hot spots that I could detect on the appliance.
The motor in the Samsung AX40 is not directly run. It's probably a DC motor anyway (I can hear a slight hum from the Novita NAP501 motor at low/med speeds).
Drav03
Hi Mosmos,
Thanks for the info? If its a problem, how come so many of them here buying online from Qoo ? AX41 is $400 plus locally? Thats a lot of difference!:s11:
ralliart12
@WussRedXLi:
I am actually reading the thread from pg1, perceived from the 1st 20 pages that you are a strong supporter of Sharp models, particularly the old models. Did Sharp quality drop? Is that why you veer towards alternative brands? Or the value-to-price ratio of the new Sharp models go downhill? I will also like a "workhorse" unit, ie I hope the main machine lasts & the only thing I need to change is the filter media.
WussRedXLi
New Time Sale low price of $279 for the Samsung AX40 from another seller....using FedEx. (you all search yourself coz don't wanna endorse too many links from qoo)
MODEL : LA-Q370SB(39㎡), only SGD269.
WussRedXLi
@WussRedXLi:
The Sharp models (at least i can say for the upper models) are most probably close to 100% workhorses, I have one unit. My wife's side relatives use Sharp and they have been using a few years.
Then Samsungs came about 1 month ago and it presented a very good performance to price ration with regards to (1) noise (2) airflow.
OEM Samsung HEPA filter is about 30% cheaper than the other usual brands, plus you can get on Amazon the replacement HEPA and/or activated charcoal filters at even cheaper prices.
You can nearly get 2 units of Samsung AX40 compared to 1 unit of Sharp A50.....with Samsung original filter @ S$75 (including activated charcoal in it) and Sharp is S$105 while the AC filter is S$69 = S$174.
You can assume that you'd change the HEPA in Singapore's conditions once every 12 months with 12hr daily operation. AC filter - no comments.
Humidification feature, also no comments.
The buyers have to choose themselves.
ralliart12
Thank you for your concise reply.
Anyway, I'd already ordered 2 units of the AX40 from the "Daiso" seller on Qoo10SG. Apparently, if you follow the "Daiso" seller, you get a $2 coupon from that shop which can be used for the AX40 price; & apparently, I can claim the coupon unlimited no.of times, i.e. many instances of individual $2-coupons. So I submitted my purchase of my 2 units (of AX40) as 2 separate orders & used 1 coupon for each submission & essentially I'm paying $283 for each unit:
Bottomline: a few clicks to get $2 discount per unit.
& btw, I saw a lot of folks asking for the English manual (for the AX40); I'd received it from the seller, so here it is:
link (it's a 7.9mb jpg file, so I provide a download link rather than an img link)
Drav03
HI,
I was checking the AX40 Samsung specs in their website. Noticed that they have the plasma ionizer built in as the virus doctor. Does this cause any harm as previously discussed in this forum due to the ozone? Any comments ??
chuanz
HI,
Most AF with ionizer releases some amount of ozone as byproduct... most ah, not all.
Anyway, for AX40, it can be turned off.
yamashita
Moderator
Moderator
For the English manual, can't seem to download the original size. Are you able to upload elsewhere?
Drav03
Hi,
Thanks for the info. Daiso (from Qoo) claim that their product AX40 is covered under worldwide warranty. So you can bring it Samsung service centre in Singapore if any problem ?
WussRedXLi
Friend, can upload it again for the benefit of others? The file i think is 141k, even with Download full res.
Anyway, I just posted that another seller (legit and many good ratings) is selling at S$279 now. =:p Time sale. =:p
Anyway, just a few bucks ba....enjoy your product!
WussRedXLi
Hi,
Don't think so leh. And doesn't make sense. By right, the device is 220V 60Hz. Our sockets are pumping out 240V 50Hz here. My home measures 235V to 239V most of the time even early morning. I don't think local Samsung supports. (the one at One Commonwealth, Commonwealth Lane)
Anyway, it's also only 1 year. I have already stress tested 1 month for you guys. :D
WussRedXLi
MODEL : LG LA-Q370SB(39㎡), only SGD269.
I did a bit of measurements from online pics, it seems that the width of the repalcement filter of the LG air purifier is 12.5 inches. The length is some 13+ inches.
So won't fit the Amazon freeship HEPA filters.
The Fellowes HF-300 can fit, but shipping is now usd41? :s11: Last time not so ex.
So for this, you can probably only get the OEM filters from qoo and stock it up. It's a 2013 model, in the future you may or may not have difficulty in ordering filters.
the good thing about this that i liek is that you can dim and switch off the LEDs. I need to place a couple layers of white masking tape on the Power LED on the AX40. Too bright. =:p
