Microsoft Surface
cy
Thanks for e reply. I intend to use a 12V power bank to charge e SP3. I'll take a look at your link. E female to female I think work with any 12V power adaptor.
Apparatus
Re
I have something similiar. For the cable you will need a 5.5mmx2.1mm connector, both side female, (see the aliexpress offer) to connect the SP3 charging cable to the power bank cable.
Aliexpress.com : Buy 5.5x2.1mm DC (most common size) to Surface Pro 3 charger cord adapter surface pro 3 charging surface pro 3 power supply adapter from Reliable cord retractable suppliers on Nice-Also-Cheap Aliexpress Store | Alibaba Group
Will the Qi-Infinity™ Powerplant 52,800mAh External Battery Pack/High Capacity Power Bank charger for Laptops, Notebooks, Netbooks, Tablets and Smart Phones be a good buy?
http://www.amazon.com/Qi-infinity-C...de_a_smtd&showDetailTechData=1#technical-data
Also its Qi-Infinity's MS Surface Pro 3 cable as well
samtang
samtang
I had a look again at the Astro link you provided. It provides a male to female connector. So don't need the 5.5mmx2.1mm connector. The SP3 cable connects to this plug provided.
There is another Anker Astro with digital readout. Much nicer.
Amazon.com: Anker® 2nd Gen Astro Pro2 20000mAh 4-Port Aluminum Portable External Battery Charger with 9V/12V Multi-Voltage Port and PowerIQ™ Technology for iPad Air mini, iPhone 6 5s 5c 5; Galaxy S5 S4, Tab 2, Note, Nexus, MOTO X, G, LG Optimu
I bought this power bank casing and batteries separately.
Wholesale Product Snapshot Product name is Seven Electric Intelligent multivoltage output POWER BANK Case Box For iPhone/ ipad Portable 6* 18650 Battery Box Shell QD-186
cy
Cool! Thanks for the infor. Your setup charged able to charge the SP3 properly? Cos based on online spec, the SP3 requires 12VDC @ 2A. So far i found the Anker Astro Pro2 and the Qi-Infinity.
Just curious, what battery did you purchase ie Brand and Model? Or just get any generic 18650 batteries?
hotyrole
in the name of portability/mobility,
it seems quite heavy to carry around a 52 800 mAh battery.
But of course if there's a need, then sure, go ahead. :)
Alternatively, you may buy 5 unit of Xiami new Battery Charger at S$29.90
samtang
The Xiaomi battery power bank provides only 5v USB. The SP3 need 12v. I think it is a tad heavy. The SP3 already provides for 8 hrs. Probably need a power bank to provide another 8 hrs may be sufficient. Anyway it is the users choice.
samtang
Got the Samsung batteries. Also can look for LG, Sony & Panasonic for reliability.
Wholesale Product Snapshot Product name is 10pcs/lot Original 18650 ICR18650-26F 2600mAh Li-ion 3.7v Battery For Samsung laptop +Free Shipping
cy
eyz
is there any affordable glass protector around?
i had 2 mobiles phone pasted with glass protector and kinda like it.
saw qoo10's lappy skin is selling it for 55$, and wondering whether there are any cheaper around?
thanks!
ComPuiTer
Answer to 2. You can swipe the map using 2 fingers.
Cannot...someone please try the following.
Open google chrome
Open google map
Open a map create by you
see you can swipe the map left and right or not
thank you
Livewings
Anybody wants my Surface 3 64GB + Type Cover (Red)?
I'm getting rid of it at a reasonable price to get a cheap tablet as I have no use for a Surface.
There's a little scratch here and there. 7/10 condition.
eyz
can leh bro.
in fact, 1 finger can swipe already.
Open google chrome
Open google map
thank you
eyz
Just got a USB 3.0 hub with RJ45 Gigabit Ethernet Adapter.
Definitely a cheap and good alternative for the dock.
The network speed is quite good as well.
Though the network status shows 1Gb and I am having 200Mbps internet, I am happy with the speed.
BTW, has anyone managed to get do port forwarding for your surface? previously, i turned my firewall off. I am able to get the 'green light' for my BitComet. I then pinpointed that BitComet wasn't added to the firewall exception. I then added BitComet to the exception manually, I am still unable to clear the amber light.
Can anyone help on this?
awful999
Hi Bro,
Can you please share where you get the usb hub with ethernet pport and how much ?
ComPuiTer
can leh bro.
Cannot...when you open a saved the map, it seems that it only capture a screenshot of that area. I go see whether I can find that problem on youtube
samtang
Try opening google map from Metro. i.e. at Metro screen do a search "map". Then look for google map. Somehow it opens the desktop map. Open your map. Can pan.
If I open Chrome from desktop, then Apps for maps, I also cannot pan my created maps.
