LG G3
jeffprobst
Any idea why it got into bootloop? Luckily can do a upgrade recovery thru LGMobile Support Tool. If not, have to make a trip down to LG service centre liao...
Kena bootloop and went to customer service centre
Was told that the local version is v20b the rest are international and may not be suitable to local set.
Best is to use ota.
doki81
Best is to use ota.
i am using custom room which is v20f~..international rom...no issue at all..
Locker12
Hi All,
Just to check, I have been having problems with my watsapp video download after the lollipop upgrade. It seems that all videos downloaded via watsapp, the sound quality is muffled and poor. Is anyone experiencing this too?
serverxeon
Best is to use ota.
boot loop is a documented problem. need to go set sth den okay liao.
i using android now 8.0 v20f, it's good.
except my battery drain abit fast... i think it's one of my apps. cos i was experiencing same problem on KK.
note the original LG OTA 20b is not rootable
tt32003
Upgraded to lollipop via OTA.
Battery drain is definitely there.
Probably need to reset to factory setting liao.
forzanetti
Upgraded to Lollipop v20b via PC suite. As mentione by many others, the battery drains a lot faster. On KK I can survive until 8-9pm with around 20% left. Just today I reached 16% by 5.30pm (with only 2.5 hours of SOT. I used to get minimum of 4 hours on KK).
Charging is also slower. I monitored it with battery monitor widget.
I did a factory reset after the update as suggested by many users here.
So far I did not see any advantages in upgrading to Lollipop (at least for me).
serverxeon
will the upgrade to lollipop remove root?
the official v20b will remove root, and it is UNROOTABLE.
for now, you need to install bumped ROMS from XDA if you wish to be rooted on lollipop.
i noticed the slow charging too... i use battery monitor too.
i only notice the slow charging when the battery is more than 90%.
when it is below 90%, with screen off, i get 800+ mA charging current.
what about you?
ralfale
How to disable the floating pop up notification on new update ? I don't like it at all very disturbing.
doki81
what about you?
i think i am having the same issue on charging speed when i am on AndroidNow 8.2 version....dont know why when i upgraded to 8.3SE...the charging has back to normal again..
enfant
anyone else having probs with v20b lollipop update? I was wondering if I could get it rolled back to kit Kat at the service center if I installed it accidently. already downloaded the ota package but I still scared scared to install :(
the notification message keeps coming on to tell me install...
p105ss
based on the responses in this thread, i'd rather not install man. Personal opinion la, cos now quite happy with the phone, battery life, etc. If not broken don't change it.
multi
I don't have the charging problem but do have 1 issue. When Battery is fully charged, the phone will remind you about the Battery is full with Vibration, Sound and Screen light up. Sometime it happens continuously for a few time in a row. It will keeps reminding in a few interval...This happen in the middle of the night and its very annoying...do you have issue?
forzanetti
what about you?
In KK, I get 800+mA charging current also. After Lollipop, I only get around 250 mA, regardless of the current battery level.
I've tried using another LG charger+cable, also same result. Meanwhile my HTC E8 still get 800+ mA using those LG chargers.
Gribber
here before someone say your charger+cable is fake.
aeng
Go Settings -> Sound -> Notifications -> Lock Screen
set to "Hide all notifications"
or go to Apps to turn off notifications for individual apps
doki81
no....mine reminder on full charge is only one time...then remain silent...did you try to use another plug/cable/power point and see what the result? 8.4 coming soon~
multi
Yes I did use other cable and charger but problem still exist...:s11:
Ok, waiting for 8.4...thanks.:)
micshang
I called the servicecentre after i updated to Lollipop. Was told, once u updated, no way to roll back.
But if u into rooting and stuff, then i guessed u can do it the unofficial way ba...
