I'll try too with my iPhone 6 and Air 2. But I have no trouble at all now (before IOS update) with Beamforming and Roaming Assist off.Just updated my iPhone 6 Plus & iPad Air, will turn on beamforming and monitor to see if still dc.
Are you using iOS?
iOS 8.3 is out today, here are some of the fixes:
Wi-Fi and Bluetooth fixes:
● Fixes an issue where you could be continuously prompted for login credentials
● Addresses an issue where some devices disconnect intermittently from Wi-Fi networks
● Fixes an issue where hands-free phone calls could become disconnected
● Fixes an issue where audio playback could stop working with some bluetooth speakers
more here...
Hi Guys
Just saw a whole lot of error messages like these:
Apr 8 22:59:29 kernel: net_ratelimit: 10 callbacks suppressed
Apr 8 22:59:29 kernel: Dead loop on virtual device vlan10, fix it urgently!
Please help!
Seems to be same as it ever was - need both types of beamforming off for ac iDevices to stay connected in sleep. Don't know if 8.3 has improved behaviour with beamforming when awake. Have not had an issue with beamforming off since 4950, so don't know what else they might have done. 4950 said it had a "workaround" for iPhone, so maybe all that has happened is Asus can remove that?Took about 15mins for my iPad Air 2 to disconnect in sleep mode. ac beamforming is off again. See if that fixes it.
I just updated to 4950 and my router cannot be seen on the wifi range..
Tried resetting and power off it also not working..
Anyone?
ASUS RT-AC87U Firmware version 3.0.0.4.378.4950
[Important] Because added the patch for 5GHz, please press and hold the reset button more than 5 seconds to reset the router after firmware updated to avoid compatibility issue.
- Added workaround for iPhone6 wireless unstable issue.
- Fixed the denying intranet access issue in 5GHz guest network.
- Fixed the UI issue when switched to AP mode from media bridge mode.
- Supported ZTE MF193A USB LTE dongle.
MD5: 242fe3dd0acfc7b4e129edd453ccb278
yes i did.. i pressed 10 secs just to be safe...Did you do the > 5 second thingy highlighted in bold?
Ok.. Some updates..I'm getting no issues thus far on 4950 & iPhone 6 on iOS 8.3
I've got one very cheap Android handset that came free with a contract, gathering dust in a cupboard. I could get it out and turn it on, but we don't use it for anything, so I'm not sure if it would be very helpful.Jong... do u have android devices to test with?
Tried 378.4950 and IOS 8.3 with all 5Ghz beamforming on - iPad Air 2 disconnected in 15 mins. Turned off "ac beamforming", but left on "universal beamforming" - lasted another 15 mins. Turned both off and its been connected for the last 12 hours.Seems to be same as it ever was - need both types of beamforming off for ac iDevices to stay connected in sleep.
I think I can say for sure that 8.3 has done nothing for that problem! Luckily I don't really need it anyway!
