ahduck
Bor lah.. Sell Asus just use money buy Linksys lor...
Not rich just that I don't drink don't gamble don't play woman... Only buy gaudge to reduce stress...
In this case, forget Linksys. Just straight jump to Cisco.
ov2rey
Good morning everyone,
I need help with setting up Static IP on my RT-AC87U router.
I have configure the below settings, but unable to surf web site and I have to switch to Automatic IP
renfred89
Does ur isp offer static ip service?
piglet_oinkoink
Hi all, till today Asus yet to resolve and improve AC87U ?
Really disappointed with Asus... .keep releasing router with problems.. AC 87U worst. overheating and firmware issues .
now my RT-AC3200 also problematic (claim tri-band smart connect which don't work ...
Wasted $ & time on Asus routers.
Overpriced and yet cannot perform as spec.
good coy should properly develop and test new product first.
trichard
Cool cool.... Do a work around on RT3200 to handle only 5GHZ ... It will be swee swee..
lynchp
help: NAS not working with router
Hi experts - I have a WD "Mybook duo" 4TB which comes with USB only.
I tried connecting to the RT-AC87U but is unable to get it to work
1) USB2 port -> NAS is detected but shows "unmounted"
2) USB port -> router does not detect anything
I have since tried NTFS, exFAT, Mac Journal, etc, and RAID O,1, JBOD -- all to no avail.
I also tried connect single HDD and memory card readers - they work fine.
I am a little disappointed. Anyone have similar issues or have solutions?
lawkoh
Thought WD My Book is A NAS?
It should have a ethernet which plug to the switch or router directly.
I used to have a My Book 1 TB, it's has no issue on the switch connected to this router.
danxiaogui86
Lol. bro. ur static ip address, gateway and subnet mask are all pointing to local.
Those settings are suppose to be from ISP.
TheDream
Yah. For M1 Static IP, you do not configure this on your router. Just configure as Automatic IP. On the M1 side, you will always get the same WAN IP, so that's how they effectively give you static IP.
Jong99
Do you all try enable beamforming for all channel ???? Any issue ??.
Yeah, 5Ghz BF still broken, at least for iDevices. They keep dropping connection, probably in low power state. It especially affects sleep mode, but can happen at other times too. With 5Ghz BF off all is good. My router and AP have been up for 10 days now and 20 devices are flawlessly roaming from AP to router, 2.4 to 5Ghz :).
lawkoh
Any difference for firmware 4950 between the official and the beta?
I am still on beta, iphone 6 + seem to DC during sleep mode.
My BF is off
Jong99
My BF is off
JK has said and I've confirmed with a binary file compare, the beta and the release are identical.
Jong99
... Mind you, if you read back, I had odd problems on the beta that I can only put down to the router not fully resetting. Reapplying the official release over the beta and doing all the hard reset stuff again fixed it. So it is worth a go.
renfred89
glad that its working well for you now.. :)
