Yeah! It's an Easter miracleglad that its working well for you now..![]()
Hi folks, this is not good. I'm on 4950 and connections are still dropping intermittently. No clear pattern of drops and BF is off. I've two notebooks with Intel 7260 and latest drivers. Every now and then, wireless icon shows exclamation mark and my Exchange and Bloomberg connections drop. Any advice?
One of my laptops is also Intel 7260 and it is working perfectly here. Make sure you DO have the latest Intel drivers. The 7260 has been a nightmare ..... lots of problems for lots of people. There have been almost weekly updates to it since it came out. I also set it to "prefer 5Ghz" in the advanced driver settings (to stop it sticking on 2.4Ghz).Hi folks, this is not good. I'm on 4950 and connections are still dropping intermittently. No clear pattern of drops and BF is off. I've two notebooks with Intel 7260 and latest drivers. Every now and then, wireless icon shows exclamation mark and my Exchange and Bloomberg connections drop. Any advice?
Hi
I bought this router from M1 during the recent IT show.
M1 installed the ONT few days back and I installed the router and setup the password via direct linkage to my laptop.
Prompted me to upgrade firmware and I proceed with it.
I reset the router thereafter (pressing the on/off button at the back) to reset
I used speedtest.com.sg and the download speed is just 79mbps and upload is 59mbps
I subscribed to the non gaming 1Gbps plan hence I wanted to ask is there any setting i need to pay attention on my router before I complain to M1
Thanks for the prompt replytest the speed again, but directly to the ONT.
the one in red is a reboot. not a reset. a reset is assumed to be using the reset button behind.
You might want to log in to webUI and ensure the firmware version you have now is 4950.
If it's now, you may want to upgrade it to 4950.
Next, if all things fail, do a reset by using the reset button and re-setup the router to ensure clean performance...
I will go back and test after work
Usually after firmware upgrade, does it required a reset or reboot?
I didnt see the message correctly previously
disconnection can be also due to the router side. Have you tried to view the system log of the wireless router? If not, you may also try uninstalling the driver for pcie-ac68 and re-installing it?
Dear all,
I am using the below devices on build 4950 - beamforming enable
I did not encounter any disconnect on my devices.
Zenfone 5
IPhone 6 +
IPhone 4
MacBook air
Sony Xperia Z1
Intel AC 7260
Below is my setting for 2.4Ghz & 5Ghz
Auto
149 /80
Best regard,
JK
Dear all,
Zenfone 5
IPhone 6 +
IPhone 4
MacBook air
Sony Xperia Z1
Intel AC 7260
Auto
149 /80
Best regard,
JK
Dear all,
Zenfone 5
IPhone 6 +
IPhone 4
MacBook air
Sony Xperia Z1
Intel AC 7260
Auto
149 /80
Best regard,
JK
Buying used ac87u for SGD125.![]()
............ you si bay di siao siao................... you si bay di siao siao.......
You mean for 5 GHz, channel must be 149 for beamforming to work?Dear all,
Zenfone 5
IPhone 6 +
IPhone 4
MacBook air
Sony Xperia Z1
Intel AC 7260
Auto
149 /80
Best regard,
JK
Bor lah .... Channel does not matter.....You mean for 5 GHz, channel must be 149 for beamforming to work?
did you test the iOS device in sleep? i mean, the dc comes in only when the screen is off leh
@JK, am using note 3 and tab s 8.4wifi. My prob is not with device dropping connection...rather - device will be connected... but no internet connectivity. I have written a couple of time here... no acknowledgement whatsoever. Asus seems to have ignore this problem altogether and just concentrated on ios related issues.
Dear Ho_kuku,
I didn't ignore your feedback. Possible provide more detail?
Wireless channel? Android build? wireless 2.4 or 5Ghz
When the wireless will drop?
Best regard,
JK
