renfred89
Hi Renfred89,
I tested 3 sets of note 3 and note edge.
Best regard,
JK
I mean the ac87u u have might not exhibit the problem cos of technical quality. The ac87u I had could replicate the problem.
If that's the case, then can confirm that some ac87u is indeed flawed lor..
ASUS@SG
Suspended
Hi renfred89,
Do you still have 87 with you?
Best regard,
JK
thiamhui
Could be due to combination of setting. Like the VLAN Dead Loop which I got is due to IPTV + USB + AiProtection.
ASUS@SG
Suspended
Hi thiamhui,
I am using M1 fibre at home and M1 do not have any IPTV.
We are very seriously into such case to improve our product.
Hi Renfred89,
if you have sold your 87 and can i send you another 87 unit help us do testing?
Best regard,
JK
renfred89
Hi thiamhui,
Hi Renfred89,
Best regard,
JK
Yes I sold my ac87u already.
Sure I can help you test..
woshi]x
Dear renfred89,
I will drop you an pm.
Best regard,
JK
Hi Asus@SG possible to check with you that you have taken note of the S6 edge and iphone 6 plus dc of the 5 ghz.
So now we just wait for your latest firmware right?
Thanks
Jurong640
Dear all,
Did another test on Samsung Galaxy Note 4 still no problem.
Model number: SM-N910G
Android 5.01
Baseband: N910GDTU1B0C7
Kernel version: 3.10.40-4887136
Build number: LRX22C.N910GDTU1B0E1
Smart network switch: Disable
Mobile Data: Disable
Test with 5Ghz on RT-AC87U - Build 5587 - 149/80mhz
Best regard,
JK
Might be because im using N910C instead of N910G. The DC is okay. Im okay with using 2.4ghz. Its the lagging issues sometimes that screwed up the experience. sometime facebook just loading slowly. Previously i have serious lagging issues, now seems fine after i forget my wifi connection and reconnect again. But still lagging issues occurs.
ASUS@SG
Suspended
Dear Jurong 640,
What is the difference between C and G?
Best regard,
JK
davemishsr
Flow Acceleration
Any idea why NAT acceleration now only shows CTF only, FA looks not enabled in merlin too. Do i need to do hard reset once more? I upgraded to Merlin.
If you disable STP in Merlin's builds immediately after a reset to factory defaults then Flow Acceleration will be enabled along with Cut Through Forwarding. Then, as you methodically activate features one at a time you check to see if FA has been disabled. If so then you simply disable that feature if you wish to retain FA.
Good luck. :)
keigo
Dear Jurong 640,
Best regard,
JK
SM-N910F for Europe
SM-N910K/SM-N910L/SM-N910S for Korea
SM-N910C - Asia, Europe, South America
SM-N910FD - United Arab Emirates
SM-N910FQ - Turkey
SM-N910H - Asia-Pacific
SM-N910G - Singapore, India, Australia
SM-N910U - Hong Kong, Taiwan, Australia, New Zealand, Chile
SM-N910W8 - North America
SM-N910C using Exynos
SM-N910G using Snapdragon
Unknown E825B1 Wi-Fi Module used in both?not confirmed(Have to dismantle SM-N910G to know for sure).
Probably that's why I don't encounter issues using 5G on SM-N910G local set.
keigo
S6 and S6 Edge are using Exynos 7420, Exynos chipset issue with ac87u routers?
keigo
my is s6 edge and iphone 6 plus.
dont mind swaping if they have. haha
Try doing this setting, see if it helps.
Network Key Rotation Interval : set to 0
Disable all Beamforming
Beacon Interval: set to 50.
ASUS@SG
Suspended
Dear Keigo,
Please do not set Network Key Rotation Interval : set to 0
In the long run the device will drown.
Please stay default 3600.
Best regard,
JK
ho_kuku
The ac3200 n ac68u thread are relatively silent compared to this one
When I still have my 87u, my note3 n tab s 8.4 wifi were also affected with WAN dropping. ...on LAN they are ok..... not to mention the lagness and frequent dc. Hope the new drivers will resolve those problems..... else I really suggest that you guys move on.... its been more than 8mths already. ... router shd be something we set it up and forget
woshi]x
Hi ASUS@SG, can answer my question, thanks. Cause I need to know if you all have already taken note of the problem with s6 edge and iPhone 6 plus. If not then I think I need to move to ac3200. thanks
keigo
Dear Keigo,
Best regard,
JK
I know it's more stressful to the router but I find it to be more stable using this setting.
No drop in wifi and and any d/c. Quickly drown then I got excuse to change new router.
