WussRedXLi
- Jun 15, 2001
Ok, come across this one which looks better than the D70, D90, D120. At least they claim to be.
PF75 electrostatic media. Looks good, 90% and 1.1 Pa resistance.
Not sure if zhun bo....need to buy and test out.
I suspect these types have a slightly higher resistance than 3M Filtrete, but can hold more particulate matter (lasts longer) and hopefully higher end filtering effect (CADR).
I know 2 of my aircon FCUs are very powerful as measured by the anemometer, the one in the MBR is somewhat 30% less airflow despite cleaning it to the best of my ability. (the MBR is system 1 while the other 2 rooms with higher airflow FCUs are system 2....all from Panasonic same family). Edit - noted that it's only at 5.3cm/s windspeed passing through the media then you'd get those results. I just measured my aircon intake and it's still about 100cm/s in low speed. So will need to test it in real life.
新升级PF75进口针刺静电滤网,非市面上卖的D70,D90和D120普通静电滤网
PF75进口针刺静电滤网相比普通针刺滤网,具有过滤效率更高、过滤精度更高、阻力更小、容尘量更大、寿命更长的优点。它可以有效过滤花粉粒径百分之一的微粒,能捕获相当于一根发丝直径四十分之一的粒子。
本商品规格:
小米滤芯使用:70*30厘米 宽70厘米 长30厘米
http://item.taobao.com/item.htm?spm=a1z10.1-c.w4004-10730907110.2.JQIjcL&id=44354836244
本商品规格:
