WussRedXLi
- Jun 15, 2001
personal use as i am allergic to dustmites. to be used daily. can recommend for both bedroom and living room? thought of buying one to put in office as well. most importantly the filters can be changed with ease.
Unfortunately, office spaces are usually not so effective due to larger volumes involved + due to central air conditioning.
Since you have allergic rhinitis due to your upper respiratory tract reacting to the dustmite droppings :
(1) First you'd need to clean your bedsheet regularly coz when you sleep and turn, that's the place where your nose would be closest to.
(2) After taking care of that, then you'd turn to an air purifier. You'd need a pretty powerful one for allergic rhinitis.
(3) Thirdly, you'd need to vacuum the floor conscientiously coz whenever you walk in the aircon room, you'd stir up dust (and the droppings).
The dustmite droppings are quite big, 10-40 microns in size. You do not really need a HEPA filtered vacuum, but anyway just get one which is as they are not ex.
(4) You would spend a lot of time in the bedroom, this is where you would want to control the dust mite population. No dust mite, no faeces. Keep RH under 60% and temperature below 25 deg C. Easily kill 50% of them.
Invest in a digital thermo and hygro.
You mentioned local sources only + filters availability, but still I'd ask you to check out qoo10.sg. I don't reckon you'd like to deal with taobao.
qoo10 has the Samsung AX40 which has powerful airflow and is the quietest machine that most of us have come across. It's just S$285 shipped, replacement filters are $78 if you tag on to the order. Get maybe 1 additional replacement filter. But don't exceed $400, else will kena GST.
Locally, it'd be the Sharp A80. Price is about $470 or so at Goh Ah Bee (google it). Check it out at Best Denki....replacement filters are also there. If that runs out, you can get from Taobao also, no need to customise, but there will be a slight reduction in airflow of maybe 30% (filters would be at 1/4th the price only though).
This is a powerful air purifier, you can run at medium speed and it'd be fairly more silent than the Samsung AX40 at high speed while having the same airflow.
6-12 months is the duration to change your filters, depending on how ngeow you are on the smell of the airflow. (the longer you change, the stronger the smell of the dust and particulate matter that's captured by the filter)
