atlantistm
My dlna server is not recognizing the entire contents of the hard drive connected to the router's USB, all content is ok from ftp, only a small amount of the content is displayed in dnla.
Tested With
4950 (Works fine)
5134 (Problem)
6065 (Problem)
6117 (Problem)
7010 (Not tested)
All upgrades done with hardware reset.
Anyone else with this problem?
Yes, I have the same problem
or1onz
meh... why are you so desperate to get BF working? with it disabled I'm reaching great AC speeds which get halved with BF. Even when it will be fixed the speeds won't get better than with disabled. At best they will equal with slightly improved coverage.
And once again I will repeat it... 2.4GHz -> long range, 5GHz -> short range or open areas with no obstacles. any single wall just kills 5GHz. It's not ASUS fault, it's just physics... DEAL WITH IT.
Hi, just wondering around what speed will you receive with those wireless devices? I understand each different device got each limited speed.
As I am going to sign a new 1Gbps contract with M1, their 68U is out of stock. So I am left with the option of 87U.
ankhazam
DL from NAS connected to router to my PC is at max 45MBps, UL around 20 MBps. Router shows up to 520 Mbps rate at that time and aroundish -62-64dBm
thiamhui
ASUS RT-AC87U Firmware Beta Version 3.0.0.4.378.7177 (http://www.asus.com/Networking/RTAC87U/HelpDesk_Download/)
- Release Note -
[For Japan Only]
Security fixes
- Fixed CSRF and XSS vulnerability when router is in default status (user does not set the router yet)
- Fixed 5G WPS pin code related issue
New features
- Added client list view button on network map and help administrator easily monitor all client connection status.
- Added the question feedback in Administration -> Feedback
- Added new DDNS provider www.oray.com
Bug fixes
- Fixed login issue when router’s IP is 10.x.x.x
- Fixed parental control-> time scheduling related issue.
- Fixed adaptive QoS device priority label dragging issue.
- Fixed network tool related issues.
- Fixed USB HDD issue when using time machine.
- Improved media server response time when new file added.
- Fixed network map UI issue when selected French.
- Added stateful server in IPv6
- Fixed the saving issue in OpenVPN server -> content modification of keys & certification.
- Fixed WAN led issue when dual wan enabled.
- Changed 5GHz driver to improved connected issue.
MD5: b7cff944c20c8575063244ab119af5a7
kero89
Did the later fw include AP mode in the setup wizard? Still on the .4xxx fw, pretty lazy to get it upgraded :D
Mecisteus
Tested With
4950 (Works fine)
5134 (Problem)
6065 (Problem)
6117 (Problem)
7010 (Not tested)
some of your files are causing DLNA to hang while scanning. try removing the problematic files by trial and error.
eeyore82
I just bought this ac87u router. Connected but when i run the speedtest oni up to 180mbps though i sign up 1gbps. I m a noob in these. May i noe wat is wrong?
GeForce
Walao
oric1
Set your "NAT Acceleration" (hardware accelerator) to Auto in LAN > Switch Control. Remember to click Apply.
BTW, you tested using wireless or cable?
ray7188
Hi guys, I have currently on 3.0.0.4.378_6117 however I have this problem of no Lan and wireless suddenly after the router is left running for a month without rebooting.
However in this state singtel Mio TV still works. The sudden loss of wireless has caused my parents data to exceed the limit twice. I also previously have this problem on an older 87 which I gotten it changed as I though it was a problem with my set.
May I check if anyone else faced this problem? I would have to reboot the router to fix it as there is no LAN nor wireless connection for me to login/telnet to check what is wrong with the router.
maylyn
ASUS RT-AC87U Red Limited Edition ;)
How about having one of the ASUS RT-AC87U Red Limited Edition? it's only 1000 pieces available for retail worldwide ^^
US Package :)
